LP died
Old Jan 8, 2008 | 01:43 PM
Buffman88's Avatar
LP died
my lp died in my 04.5 what is the cheapest and easiest route to go for another one?
Old Jan 8, 2008 | 01:52 PM
BRayls's Avatar
carter, holley blue pumps are becoming more and more seen,and probably the cheapest options. finding one off a truck that someone pulled early on. I like the fass pump, not cheapest though.
Old Jan 8, 2008 | 02:00 PM
shortbed rv's Avatar
Assuming your pump is on the filter canister. If you can blow through the pump then you can just add a holley blue. Lots of threads on the install. however if the stock pump is blocking the passage way then you need to by a pump adapter from Vulcan or someone and remove your pump so the holley can push through the filter.
You can buy a canister pump from geno,s as a replacement, the stock pump sucks and so will a replacement.
Old Jan 8, 2008 | 03:43 PM
thejoker502's Avatar
Warranty
If you have under 100K and the pump is on the block have Dodge fix it under Warranty. If not go aftermarket as advised above.
John
Old Jan 8, 2008 | 04:11 PM
Dieselnick's Avatar
If you go with a BD set-up get the one that removes the stock pump, not the other. Get some ear-plugs too.
Nick
Tommy93w350
20
Nov 1, 2005 11:07 PM
Rigg4x4
Dec 13, 2002 01:40 AM
Desert Diesel
Dec 6, 2002 03:54 AM
Copenhagenjunkie
Nov 29, 2002 09:10 AM
