low speed surging idle
Old Dec 7, 2007 | 09:04 PM
adventuris's Avatar
hi , truck has a surging idle , when running around 1100 - 1400 rpms the idle wil surge up and down , below 1100 its fine above 1500 its fine . any ideas whats causing this .
Old Dec 7, 2007 | 09:25 PM
vzdude's Avatar
DTR's 'Go to Guy'
Any codes? Several things come to mind. Most will set codes. Turn key from off to on 3 times ending in the on position. Codes will read off in the odo screen.
Old Dec 7, 2007 | 10:45 PM
soulezoo's Avatar
DTR 1st Sergeant
Turn off your power puck and then see if it still does it.
Old Dec 8, 2007 | 07:25 AM
adventuris's Avatar
pulled codes p0602, p0633 one is for running programer and other is for security key , why would the puck be causing it its been on there for awhile and this is only a new problem .
Old Dec 8, 2007 | 09:09 AM
Hounddog's Avatar
Maybe a dirty or bad FCA.Do a SEARCH on it.
Old Dec 8, 2007 | 11:24 AM
vzdude's Avatar
DTR's 'Go to Guy'
That was my next guess Hounddog. I just can't fathom why only at a particular rpm's. The puck could be causing a problem.....they can go bad. Also try recalibrating the apps. IIRC, you unhook the batteries, set for 10 minutes or so, re hook them up and with the key on/engine off press the accelerator slowly to the floor and back. See if it makes a difference at least.
Old Dec 8, 2007 | 01:37 PM
Hounddog's Avatar
Almost forgot.One way to see if its a sticking FCA is add a pint or two of the ashless two stroke oil to the fuel.If its sticking it will clear up some time during that tank of fuel.Once its gone and filled back up it will start surging again.That trick works.
Old Dec 8, 2007 | 08:25 PM
adventuris's Avatar
it does not do it all the time , it will do it one day , then not for a few , it seems to do it more after running on the highway for awhile at constant speed then when you get off and are just running around 30 - 40 at 1100 - 1400 rpm it will do it
Old Dec 8, 2007 | 08:33 PM
vzdude's Avatar
DTR's 'Go to Guy'
That also can be one of the "side effects" of programmers and boxes. That is right where the power band kicks in as well. It never did it before ? or never noticed it before?
el toro
Aug 29, 2020 10:50 PM
chopper9451
Jun 30, 2009 11:38 PM
spitzair
Jan 30, 2006 04:53 PM
spitzair
Jan 24, 2006 03:42 PM
