Low Speed Rattle
Old Jul 28, 2009 | 06:30 PM
finndogg54's Avatar
Low Speed Rattle
Looking for a little insight..... Ive noticed recently while rolling thru the neighborhood, im hearing a rattle. it sound like when you get a rock in a hub cap. it happens at about 15mph with no throttle, im just coasting. i checked the flex plate teeth to see if maybe one broke off.......nope. and ofcourse the caps. Can it be an internal tranny issue? all ideas welcomed.
Old Jul 28, 2009 | 06:51 PM
Jeff in TD's Avatar
Could be anything from a heat shield somewhere to a rock or other debris in the wheel.
If it happens at really low speed, maybe you can walk along while someone idles the truck through the neighborhood, and narrow down the area from which the sound comes...
Old Jul 28, 2009 | 07:21 PM
finndogg54's Avatar
but what gets me is that it only does it at around 15mph or faster... until there is too much road noise. also no sound thu slower than 15mph suspension articulation.
Old Jul 29, 2009 | 11:00 AM
eights88's Avatar
mine is doing it also check your axel u joints thats what mine is.
Andy
Old Jul 29, 2009 | 01:56 PM
finndogg54's Avatar
How do you go about checking them...Do you need to jack it up?
Old Jul 29, 2009 | 08:56 PM
finndogg54's Avatar
Come to think of it...the noise resembles what a hot peice of metal sounds like while cooling of.
Old Jul 29, 2009 | 09:07 PM
RiverRat2's Avatar
Smile
Have to ask,,,,,not meaning to hi-jack yer thred,,,,
How is your tire wear and steering/ride with the Kore Leveling kit w/tha bilsteins????
Old Jul 29, 2009 | 09:09 PM
RiverRat2's Avatar
Smile
is your truck a 2500 or 3500?????
Old Jul 29, 2009 | 09:28 PM
finndogg54's Avatar
Same as stock tire wear....and drives as well as it can with the minimal adjustments that can be made to the alignment, its a 2500. The updated steering made a huge difference.
ColoRoadie
Nov 9, 2011 12:02 AM
93 dually
Dec 20, 2005 10:03 PM
FiverBob
34
Dec 11, 2003 08:17 PM
