Just Started Smoking
Old Jul 29, 2009 | 01:17 PM
SaylorCE's Avatar
"03" 2500 with 160,000 miles maintained very well just started smoking (i believe not oil) both at idle and while on the road. Any ideas thoughts. Nothing done to engine except normal oil and filter change and fuel filter change. Mileage is mainly highway and I am very light footed, though for the first 100,000 miles did a lot of pulling.
Thanks,
Carl
Old Jul 29, 2009 | 01:26 PM
rip 112's Avatar
May have an injector on the way out.
Have you checked your turbo for any seals leaking? Check for play on the shaft.
Any overheating issues? If you don't think it is oil it can possibly be coolant...
Old Jul 29, 2009 | 02:45 PM
Mr Bee's Avatar
What color is the smoke? White usually means unburned fuel = Bad injectior
Does your oil smell funny? Like diesel fuel? Hows the oil level? Does it run and idle smooth?
Old Jul 29, 2009 | 02:55 PM
JP-4.5's Avatar
Do you have boost gauges? Does boost look low?
If it does or you don not have a gauges then I would check your hoses from turbo to inter-cooler and intercooler to intake..
If it has a boost leak you would see some smoke..
Old Jul 29, 2009 | 03:13 PM
rich's Avatar
bad injector on the 03 will also blow black. it will also start getting harder to start
Old Jul 29, 2009 | 10:20 PM
SaylorCE's Avatar
No boost gauges. A little slow starting, and idle is not as smooth as before. Fuel mileage is still good and power also seems good. Smoke appears dark, oil level is good. No over heat issues.
Carl
newguy2005
13
Jul 8, 2010 03:57 PM
2500Ram
Oct 16, 2009 12:24 PM
djja918
Aug 22, 2008 03:36 AM
jvanick
15
Jun 13, 2008 05:21 PM
cejrunner
Dec 19, 2007 01:52 PM
