Just started smoking!
Old Dec 19, 2007 | 07:42 AM
cejrunner's Avatar
I know smoke is something most people want. Mine just started all of a sudden. It has a slightly rough idle and i can load it up and put out a serious cloud. I can also make people dissapear behind me. I do like the smoke but i do not like how i started getting it. Does anyone have any suggestions. I am thinking a injector.
Old Dec 19, 2007 | 09:20 AM
Thedieselkid's Avatar
What is your FP...has it changed? Sounds like you may have an injector issue.
Paul
Old Dec 19, 2007 | 09:32 AM
cejrunner's Avatar
FP is steady at 18. Had a diagnostic done and no codes present and no abnormal readings. The puzzling part is there is only 118,000 miles on the truck.
Old Dec 19, 2007 | 10:48 AM
Need95-00CTD's Avatar
Sounds like an injector to me as well, possibly a cracked nozzle. Does it smoke hard on startup?
Old Dec 19, 2007 | 11:27 AM
cejrunner's Avatar
Not really, It does stumble a bit right at start up, like it has a slight liad on it. That goes away just after it starts. It responds and drives fine. it just smokes to high heaven.
Old Dec 19, 2007 | 12:05 PM
Alright, then it doesn't sound like an injector. Is your CEL on? It sounds like your MAP sensor might be shot, or unplugged.
Its what guys wire a "Smoke Switch" into, basically if its shot it will tell the engine your at full boost all the time, and feed it full fuel all the time. Do you have a Pyro? It should be reading toasty if your MAP sensor is shot.
Old Dec 19, 2007 | 12:32 PM
cejrunner's Avatar
I had our local diesel shop hook up to it and all his readings were normal. I have the Edge EZ installed so it is hooked up with the MAP sensor and the boost sensor. I wondered if the Edge crapped out or something associated with it. The shop i took it to was booked up and couldnt get to me till after the first of the year because of vacations and such. I have since dropped it off at a different shop and have not heard back yet. Oh yea, no CEL and no pyro.
Old Dec 19, 2007 | 01:10 PM
I would have tried pulling the MAP sensor from the edge module and sticking it straight where its supposed to go. You may have a shorted wire or something on the Edge box thats causing it, even with the box turned off. If its at a shop your pretty much screwed unless you have the keys and its in the lot.
Old Dec 19, 2007 | 01:14 PM
cejrunner's Avatar
I figure when i get it back this evening i will try that. I would have tried it before i took it but the stock boost elbow is at home and i was not sure if i would screw things up by not putting it all back to stock.
Old Dec 19, 2007 | 01:52 PM
Well, without the stock boost elbow you'd throw an overboost code, but it would determine whether the MAP sensor is shot or not.
newguy2005
13
Jul 8, 2010 03:57 PM
2500Ram
Oct 16, 2009 12:24 PM
SaylorCE
Jul 29, 2009 10:20 PM
djja918
Aug 22, 2008 03:36 AM
jvanick
15
Jun 13, 2008 05:21 PM
