low RPM vibration
Old Sep 21, 2009 | 11:31 AM
hath27's Avatar
Question low RPM vibration
Posting for a friend: He has a '06 3/4 ton, 6-spd 4x4 w/ approx. 90k on it. Truck is stock.
Recently, the truck has started acting up w/ an intermittant vibration.
It only seems to occur from off idle and gradually diminishes as you go up in RPM. It occurs in every gear, but is more prevelant in 1st or 2nd. Very noticable when towing a load.
Performance has not suffered.
Doesnt seem to noticable if you just rev the engine while stopped. Only occurs under load?
He had the rotors turned, tires balanced, no change.
This past weekend, I personally experienced it. It did it consistantly on Friday when we towed a trailer to Pueblo, CO. But on Saturday, we did the EXACT same trip, and could not feel ANY vibration.
Any thoughts????
Old Sep 21, 2009 | 10:04 PM
dfranks's Avatar
possibly,rear u-joint. Mine was seized so it would only vibrate at a certain rpm, due to it being out of balance. Also mine went very gradually.
Old Sep 28, 2009 | 04:11 PM
Dextreme's Avatar
I am experiencing the same issue with my 2004.5. I have an appt at the dealer on Friday and will let you know what I find out. If its not the rear u-joint, I am thinking it might be the Center Support Bearing.
Old Oct 2, 2009 | 01:25 PM
Dextreme's Avatar
Dealer called and said it was my driveline u-joints.
Old Oct 2, 2009 | 02:02 PM
cincydiesel's Avatar
U-joints or carrier bearings..
city slicker
Oct 24, 2007 10:23 PM
dodgedsl03
Jan 18, 2007 10:08 PM
Breck-Ram2500
Jun 2, 2006 07:47 PM
spitzair
Jan 24, 2006 03:42 PM
fishin fever
Feb 22, 2004 08:32 PM
