Loud Fuel Pump?
Old Dec 1, 2010 | 08:38 PM
The Witchdoctor's Avatar
Loud Fuel Pump?
First off, I am a newby to the cummins, so thank you all for letting me be a part of a great Forum! I have been reading for days! Anyway, I have an 03 2500.... cranks great, but after i start it, the fuel pump is very loud and seems like it is going in and out... if you watch the lights in the cab, they actully dim when it does it. I also noticed the amp hand stays about 12 volts or so for a couple of minutes, then chages fine... no running issues with it or anything... just looking for a little guidance...
Old Dec 1, 2010 | 09:09 PM
rjelliott's Avatar
usually thats the glow plugs cycling after you start that makes the lights dim.
Old Dec 1, 2010 | 09:16 PM
Thanks!
Old Dec 1, 2010 | 09:40 PM
Txwelder's Avatar
Not glow plugs, heater grid.
Old Dec 1, 2010 | 10:05 PM
Bankdude's Avatar
X2
Grid Heater.
Located between the Intake Plenum and Intake Horn.
Heats air going into the engine on cold days to help startup.
Must be cold in Tn...
Some folks in warmer states remove them to try to increase cold air flow and reduce turbulence. Search for grid heater deletes. Basically a square that replaces the heater.
Old Dec 2, 2010 | 10:34 AM
26 here this morning... Which for us is about right for this time of year.. I didnt know if it was a normal deal about the light dimming and such... Thanks Guys!
Old Dec 2, 2010 | 06:30 PM
rjelliott's Avatar
Well hell i guess you learn something new everyday! My old ford and chevy had them. never knew that the cummins did not run them. Thanks.
jlarmour
Jul 23, 2015 10:59 AM
mstep3
17
Nov 3, 2008 06:48 AM
Tate
Aug 1, 2008 06:15 PM
cyoung
Feb 8, 2007 12:00 PM
Commatoze
19
Aug 8, 2004 09:57 PM
