Lift Pump and Quad Race Question
Old Sep 18, 2007 | 09:20 AM
Big Rig's Avatar
While running up the interstate, unloaded, level 3 race, fairly decent incline, crusing speed of 70-75 mph, the truck started hesitating/missing. Looked down at fuel pressure, it was at 5 psi. Switch Quad back to Level 1, it cleared up, approx 8 psi and ran fine. Level 2, same thing started hesitating/missing and back to 5-6 psi.
I change my fuel filter at every 5k, should be OK. Is the lift pump failing or is it wanting more fuel than the lift pump can keep up with. 57k on stock pump.
Old Sep 18, 2007 | 09:30 AM
SSminnow's Avatar
At 5-6PSI, should be OK at the power levels you are at. Mine was still fine when it was at 2-3 PSI. I finally replaced my LP when it hit 0 under boost. Does not mean you are not experiencing fuel loss however. You very well maybe. I woul djust have to think at 5-6PSI you would be OK. Now, of course, if you plan on keeping your truck for awhile, for teh low cost of a LP, I would just go ahead and get it over with. Replace the crap LP with a Walbro (or FASS) and never have to worry about it again. Ever.
Old Sep 18, 2007 | 11:38 AM
Big Rig's Avatar
Which model of the Walbro or Fass (?? GPH) will work best for my setup. Keeping in mind, I'm planning to upgrade to a Smarty in the future...........
Old Sep 18, 2007 | 04:37 PM
SSminnow's Avatar
The WAlbro 392 from Glaicer
QWKSLVRZ06
Nov 26, 2011 02:59 AM
BigBully
Mar 18, 2009 10:01 PM
BigJohnston
Feb 7, 2008 06:14 AM
jaredb900rr
Sep 7, 2006 10:13 AM
LinearX
14
Jun 14, 2005 04:48 PM
