Lift Pump Location
Old Nov 14, 2009 | 04:30 PM
2FEATHERS's Avatar
Lift Pump Location
I have a 2004 and pretty sure my lift pump is in the tank but ready that they did not install that in the tank til 05? Nothing behind filter canister? Looking to upgrade to an external frame mounted pump. Any suggestions?
Old Nov 14, 2009 | 05:23 PM
annabelle's Avatar
What is your build date?
Old Nov 17, 2009 | 02:27 PM
Red Feather's Avatar
early 04.
Old Nov 17, 2009 | 02:32 PM
Sorry not early 04. mfr date is 10-03
Old Nov 17, 2009 | 06:50 PM
annabelle's Avatar
[QUOTE=Red Feather;2631132]Sorry not early 04. mfr date is 10-03[/QUOTE That's an early 04.
Old Nov 17, 2009 | 07:58 PM
annabelle's Avatar
Sorry, my computer keeps disconnecting on me. I think the LP would be about the size of a roll of half dollars located on the drivers side of the fuel filter canister. Geno's Garage now sells a stock replacement for it. Folks correct me if I full of it........they weren't around when I first replaced mine with the in tank model.
Old Nov 17, 2009 | 08:28 PM
navman28's Avatar
I know on the 05's the LP is on the side of the fuel canister.
Old Nov 17, 2009 | 09:31 PM
Spooler's Avatar
In 05' they went with the intank LP. If the LP has failed and was replaced under warranty on the 03' to 04.5' trucks Dodge replaced it with an intank LP underwarranty.
If you have no LP behind the fuel filter canister and only a gold anodized line with a bango bolt you have two choices. Find an orignal fuel filter canister and replace the one in your truck now with the LP or put in a draw straw setup or similar that is offered aftermarket.
Old Nov 17, 2009 | 10:25 PM
Spooler, do you know if the fuel filter canister with the LP on the side of it is more expensive / more hassle than the $360 (parts) to replace the in tank LP? Does anyone know? I assume either one is still a problem at this point. I am thinking about a FASS or air dog now. I thought I saw a thread on installation guidlines for a DIY?
59FORD
Apr 7, 2006 12:28 AM
jlipskoc
13
Nov 9, 2005 10:26 PM
Equalizer 2
Oct 24, 2005 09:44 AM
MARKY MARK
Dec 21, 2002 11:04 AM
