lift pump
Old Sep 21, 2005 | 03:39 PM
theinstag8r's Avatar
lift pump
i think my lift pump is going.....it used to read 8.5psi on the gauge then last week it started reading 2psi on cold start up in the am and 6psi after sitting in the sun all day......brought it to the dealer and after checking they said it's fine thats normal......anyone with some input??????? in case someone askes my fuel pressure gauge is hooked to the inlet side of the injector pump right after the filter and i did change the filter....
Old Sep 21, 2005 | 04:50 PM
rico334's Avatar
Instag8r-
I can't help with an answer but I am sure glad you brought this up. I was just in a diesel service center a couple of weeks ago picking us some stanadyne and me and the guy got to talking about lift pumps and he really suggested I install one in my truck.
I think I could probably do this myself, but have no idea where or what parts I need to do this. Can you tell me where you got yours and what kind of job it was to install. Also, is this a guage that is just mounted by the filter or do you have it routed into the cab?
Thanks alot,
Rick
Old Sep 21, 2005 | 06:13 PM
my fuel gauge is mounted inside the cab......i will not put a stock lift pump back on if i do it myself..... i've read the stock unit is expensive (around $400.00)...if dodge will replace mine fine. i'm getting ready to order a holley blue pump and install that....either pump looks fairly easy to install....( the stock one easier because there's no cutting or fabricating)......but i do have another question??? we'll see if anyone will answer..... if i run a blue pump inline with the stock pump and the stock pump fails will the blue pump push fuel through the stock pump and keep the truck running????
Old Sep 22, 2005 | 11:07 AM
kimber's Avatar
Not according to This Link
Old Sep 22, 2005 | 04:10 PM
thanks...looks like i might just run a pusher pump and buy a filter housing from an 05 and solve the problem
Old Sep 22, 2005 | 07:12 PM
J BODY's Avatar
You can't get a "stock" lift pump for the 03-04.5 Common rail engines. They have been superceeded to a kit that puts the lift pump in the tank like the 05's have. Done probably a dozen of them at work.
Old Sep 22, 2005 | 08:10 PM
you can get them if the dealer has them on the shelf....i found one at the first dealer i called but too expensive for something that fails
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
