Leaking cpolant... anyone had it leak from here?
Old Oct 1, 2009 | 04:50 PM
ram4tow's Avatar
Leaking coolant... anyone had it leak from here?
I was just wondering if anyone has had a leak of coolant from the 5" ( or so) rubber hose that connects the rad's coolant line to the heat exchanger. its metal most of the way but theres just a small section that is rubber. mine seems to be dried out and cracking.
Old Oct 1, 2009 | 04:56 PM
06RAM2500's Avatar
Talking on the passenger side of the block, towards the bottom??
Old Oct 1, 2009 | 05:11 PM
ram4tow's Avatar
yea haha i figured id stop being lazy and search it ... i found a solution to my problem! thanks tho and yes thats the area where its leaking like mid -block rear passenger side!
Old Oct 1, 2009 | 05:14 PM
bansh-eman's Avatar
yes it is very common. I just had mine leak last week. Grab a socket and reach in there and tighten her up and it will stop. Once you drain your coolant look at getting the auto tightening clamps rather than the worm gear type.
Old Oct 1, 2009 | 05:33 PM
06RAM2500's Avatar
The hose is wire core type, just like transmission hose. I don't believe you ever have to change that piece out.
Old Oct 1, 2009 | 05:36 PM
bansh-eman's Avatar
The hose can dry out and crack. I went to a dealer and the hose just looks like typical heater hose thats reinforced. They wanted 15 bucks for it! Luckly mine wasn't cracked, just needed to be snugged up.
Old Oct 1, 2009 | 05:59 PM
ram4tow's Avatar
well she isnt leaking alot just a lil puddle if it sits for a while.. no worries i'll check it out when i get back home! if i have to replace it then thats fine i have no issues with 15bucks ! could be alot more (***********) haha
Old Oct 1, 2009 | 06:01 PM
ram4tow's Avatar
hmm not allowed to say ******* ship?
Old Oct 1, 2009 | 06:05 PM
ram4tow's Avatar
guess not??? lol my bad
Old Oct 1, 2009 | 06:23 PM
bansh-eman's Avatar
It wouldnt leak much fluid. All the threads said it only leaked a little during temp changes, night time to mid day heat. or Vice versa. I just tightened the hose the other day and its stopped. My overflow was empty so I grabbed a bottle of coolant today and topped it off.
Old Oct 1, 2009 | 10:11 PM
bkrukow's Avatar
Mine leaks to. Its always done it and Ive yet to have to add any coolant (90,000 miles) so its not much of a leak. I have a spot in the garage abought the size of a dinner plate but it never realy gets any bigger.
Old Oct 1, 2009 | 10:13 PM
CoastalDav's Avatar
Thats about one stupid piece of engineering. Mine leaked when I first got my truck. Thought is was tranny fluid till I got my figure on it. Had to search here to find out what the hech. Behind the turbo is not a good place for a rubber part even with a heat shield.
Dave
Old Oct 1, 2009 | 11:39 PM
Jeff in TD's Avatar
There are tons of threads on this leak. Seems to effect mostly 06.
Try tightening the clamps. 95% of the time that seems to be the cure.
bigragu
Feb 22, 2010 06:13 PM
The_Head
Apr 30, 2009 10:47 PM
Clucker
Jan 1, 2009 10:28 PM
Spooler
Nov 1, 2007 09:20 PM
steven
Aug 14, 2006 02:49 PM
