Has anyone here had to do this mod?
Old Apr 30, 2009 | 01:22 PM
The_Head's Avatar
The fuel screw extension...
http://www.idahobombersforum.com/tip...nfuelscrew.htm
If you have, tell me how it went and what to look out for, if anything.
I want some cheap power for a change.
Old Apr 30, 2009 | 04:17 PM
stinkindiesel's Avatar
This works only if your screw bottoms out before the engine runs away... have you found your unmodded screw to be too short? Mine went runaway with about 8 1/2 turns past the stock setting. Adding material to a screw that's either long enough or hasn't been maxed out is a lot of effort for naught.
Get a buddy and wind your fuel screw in until it runs away, then back it out 1 turn. If it bottoms before then, break out the welder.
Old Apr 30, 2009 | 04:27 PM
apwatson50's Avatar
I did it when I re-sealed my current pump, so I don't know if I needed to or not, I was just doing everything I found to get more fuel.
Old Apr 30, 2009 | 06:45 PM
SkinnyBTN did I'm pretty sure.
Old Apr 30, 2009 | 07:53 PM
RollinCoalSmoke's Avatar
I did it on my 93. When I started turning it up it only went a little till it bottomed out. Pulled the fuel screw outta the 92 and it was 3/4'' longer so I welded a piece to it. Now it's between an 1/8 and a 1/4 turn from runaway. It doesn't take much amperage on the welder to burn it up so be careful when you add to it. And I put the other half to 3/4 of it in a water tray to keep the rest of it cool while I welded on it, don't know if it was neccessary or not but it worked for me. Good luck with it.
Old Apr 30, 2009 | 10:47 PM
Trooperthorn's Avatar
Mine (91.5) only went in a turn and a half from stock then bottomed out. I plan to do this. Possibly this weekend as I am driving the rc again.
cjones42
Jul 6, 2019 09:49 AM
sallyman1
13
Feb 13, 2008 09:24 AM
HighTen
Nov 5, 2005 10:04 AM
t-15 firefighter
Sep 17, 2005 01:08 PM
lucey
16
Jul 11, 2005 11:21 PM
