"lamp out" question
Old Apr 21, 2008 | 08:20 PM
nel76914's Avatar
"lamp out" question
my "lamp out" on my display keeps going on and off repetidly, making my beeper go off and on really fast all the time i'm driving what can i do can i take that ringer out?
Old Apr 21, 2008 | 08:22 PM
rip 112's Avatar
Check all of your light sockets and make sure nothing has come unconnected or loose. If they are loose vibration will trigger the beeper and lamp-out light.
Old Apr 21, 2008 | 10:33 PM
jdh's Avatar
jdh
Replace your tail and brake lights with glass based bulbs (the ones in there have plastic bases). After a while, the contacts on the bulbs heat up enough to melt the plastic, causing the contacts to sink into the bases and not make contact. If you can't find the glass based bulbs, carefully bend the contacts out away from the bulb. I did that and got another 2 years out of them.
Old Apr 22, 2008 | 03:31 AM
Dodgezilla's Avatar
These trucks have sensors that tell you when you have a bulb getting ready to go out. The problem is that you don't know which one it is until it actually fails. It's almost always a tailight bulb and it usually is one of the two center bulbs. All 6 bulbs in the two tailights are the same and many of us just change them all at once just to fix the problem...
Old Apr 22, 2008 | 10:50 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
mine drove me crazy for 3 mths!
Mine did the same dam thing. For 3 months!
I finally pulled the tail light assemblies out and checked each bulb for continuity and found both brake light bulbs weren't making good contact. I hit the contacts with a small stainless brush and stuck them back in.
Haven't had any more trouble.
I know what you're going thru with the dinger...i COULDN'T TURN THE STEREO UP LOUD ENOUGH TO GET RID OF IT
Good luck.
db
Old Apr 22, 2008 | 01:05 PM
nel76914's Avatar
alright thanx guys
Hoss
21
Dec 3, 2016 02:49 PM
Buffalo
Mar 15, 2006 05:26 PM
Pickle
Mar 26, 2005 11:57 PM
tripper=t57
Feb 5, 2005 12:26 PM
Desert Diesel
Dec 9, 2004 10:03 PM
