Idle Options ??
Old Aug 15, 2005 | 11:34 AM
bdist's Avatar
Idle Options ??
I am from the frozen north and wanted to know what options I have for a high-idle (fast- idle ?) during warm-up or extended idle periods in the cold.
I heard about a TSB for a fast idle through the cruise control, however I do not think it is available in my '03.
Looking for suggestions.....
Thank you in advance
Old Aug 15, 2005 | 03:17 PM
jawmail's Avatar
Does not work on the 03's sorry. Your only option I know of is a stick.
Old Aug 19, 2005 | 05:48 PM
hoser's Avatar
Install an espar or similar heater. Keep the engine nice and toasty even at -40, uses less fuel than idling and you can use a remote control to turn it on or a timer.
Old Aug 20, 2005 | 12:55 AM
StrokeThisCTD's Avatar
i dont have the high idle feature but my Bullydog Power Pup lets me adjust the idle. i just plug it in and it lets me adjust the idle in 100RPM increments
Old Aug 20, 2005 | 12:03 PM
STATELINE's Avatar
strokethisctd,
after you have programmed your truck with the bully dog, you should be able to set you high idle with the cruise control, with the truck at idle in park, & no foot on the brake, turn on the cruise & hit set & you can adjust it up & down with accel & decel. I know my 04 worked this way after I programmed it
Old Aug 20, 2005 | 01:48 PM
well i sure didnt know that. thanks for the advice. ill check it out later
Old Aug 20, 2005 | 07:56 PM
harleybill38's Avatar
Stateline I didnt know that ,but I tried it and it works,thanks
what rpm do you set it at to warm up in the winter?
Old Aug 21, 2005 | 11:42 AM
STATELINE's Avatar
I usually set mine around 1100-1200 warms up nice, also keeps it nice & cool on hot summer days, air cond. works a little better at high idle. a side benefit it may eliminate problems that I've heard people having with DC saying "too much idle time" when they have injector problems
Old Aug 21, 2005 | 02:44 PM
wow i tried it today and sure enough it works like a charm.
Old Aug 21, 2005 | 05:42 PM
wvcowhauler's Avatar
A friend of mine as a device on his powerchoke that allows him to set the idle up. is consists of an on/off toggle switch and a dial that you use to adjust the RPM's. anyone one ever heard of something like this for dodges? i would like to have some way to set my idle up also, wonder if you can "trick the computer into thinkin its an auto and using your cruise????
Old Aug 21, 2005 | 11:51 PM
BlueDually's Avatar
I got mine through a local Dodge dealer, on the box it says dieselservices.com.
It works great, push button to speed up, tap brake to slow, **** for rpm+/-
Old Aug 22, 2005 | 10:58 AM
jkitterman's Avatar
If the intake air temperature is low enough on a 2003, it will fast idle by itself after about 2 min but don't idle any more than absolutely necessary.
qzilla
218
Jan 30, 2008 08:20 AM
rdc
26
Jul 31, 2006 09:17 AM
dieselnewbie
Jan 18, 2005 10:48 PM
Lil Dog
Nov 4, 2003 06:57 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
