Idle hunting when cold
Old Jan 26, 2011 | 10:21 AM
4CEFED's Avatar
When I first start my truck the idle will hunt for a bit, with the voltage dips and comes back up. Its only for a minute or so; just wondering if anyone knows what this is, or could point me in the right direction while I'm looking for the problem
Old Jan 26, 2011 | 10:48 AM
07BigHornRam's Avatar
mine does the same. the voltage drops cuz of the grid heater turning on then off. i notice an rpm change when this happens but nothing extreme like only 50-100 rpm . just enough to change the tone of the engine. how much of a idle hunt are u having?
Old Jan 26, 2011 | 10:55 AM
Colo_River_Ram's Avatar
With age comes the cage
It is normal as 07 said the grid heaters are cycling and the truck is going into automatic high idle. Do have the manual hi idle enabled?
Old Jan 26, 2011 | 11:04 AM
yeah i forgot to mention as Colo stated if its real cold out the truck will start out at 1000 rpms compared to the normal. Also i notice with mine when i let it run for about 2min at the 1000 rpm the truck seems to act like its missing. Only after you step on the brake the engine goes back to a nice smooth idle. But think i read somewhere on here this process is normal
Old Jan 26, 2011 | 11:12 AM
07,
The "missing" or "stumbling" as I call it can be attributed to the voltage fluctuations the ECM is getting from the grid heater drain.. They need an UPS system for the trucks computer
Old Jan 26, 2011 | 03:20 PM
4CEFED's Avatar
sounds like its normal. Another thing I learned
Old Jan 26, 2011 | 03:29 PM
El Borrego's Avatar
The voltage drop is due to the grid heaters. After a few cycles it will go to normal generation. High idle is normal when cold and will even occur if it's sitting idling after warm up. It's built into the computer system. It gets cold here in TN also but not as much as CO.
Old Jan 27, 2011 | 09:51 AM
05HDRAM's Avatar
If you have the manaul high idle enabled, but it up to 1200 and it will smooth out. That factory jump to 1000 is just not smooth for one reason or another.
braxton357
0
Jan 11, 2009 08:37 PM
quadstar
Jan 3, 2009 01:42 AM
Ram1999
Feb 11, 2007 10:49 AM
wings
Nov 8, 2004 05:32 PM
