hub bearing going out?
Old Mar 15, 2008 | 01:58 PM
Caterpillartim's Avatar
Last week i noticed that there was a slight wine coming from the front end of my truck. well it got a lot worse this week and turned from a wine to a loud clicking at low speeds and a vibration and higher speeds. i jacked up the rear end and there was nothing coming from the tranny, drive shaft or rear end. I then jacked up the font end and didnt find any excsive play in any of the u joints. The only thing that was a little off is the left tires didnt spin as eazy as the right. I really dont want wait for somthing to wrong but i dont want to pay 300 pluse dollers of a hub if i dont need it
Old Mar 15, 2008 | 09:52 PM
anyone have one go out
Old Mar 15, 2008 | 10:18 PM
Raspy's Avatar
Sounds like you are on the right track to me. My hubs didn't go out but I changed them at 126,000 miles to go to the Dynatrac setup. In the process I found the axle U joints were shot. That is probably not causing your vibration but the driveline U joints up front could. It might be hard to confirm bad U joints unless they are really bad with obvious looseness or dripping rust.
If you can't pin it down for sure, you could pull the caliper to remove the brake pad drag and spin the wheel. If they sound like they are grinding or have any play you may have found it. I think I'd pull the driveline first and look for play or binding in the joints.
John
Old Mar 15, 2008 | 10:28 PM
raceguy13's Avatar
I just replaced a u joint in my passenger side axle shaft. It wasn't sloppy, but was binding up. I couldn't rotate the tire by hand if the steering wheel wasn't straight ahead.
Old Mar 15, 2008 | 10:34 PM
ILLINOISRAM's Avatar
For what it is worth, RockAuto.com sells the assy. cheaper than anywhere else. For my 98 non abs, they were $132 plus $15 sipping apiece. I wish i would have known this before i paid $300 for one. It is even the same timken number listed right on the website as the one on the box that i bought so i know they are the not cheap knockoffs. Tim
Rafter B
Jan 11, 2009 08:40 PM
mt72916
Apr 10, 2008 09:42 PM
jlipskoc
Dec 4, 2005 02:35 PM
vikes5555
Nov 30, 2005 08:02 AM
jaconst
May 30, 2004 12:08 PM
