howling
Old Dec 14, 2007 | 12:06 AM
redneckwilly's Avatar
howling
So today i was driving on a 100km/h road and i came up behind vehicle and had to slow down, as i was following this vehicle i began to hear a howling noise coming from the diff I think. It will only howl going 95 to 105 km/h and when i step on it it will stop. I was thinking a bearing has begun to go but want to make sure.
Old Dec 14, 2007 | 02:01 AM
bsj04's Avatar
fill out your sig so we know what you have. if it is a quad cab long bed it might be the carrier bearing. thats what mine was doing when i replaced it.
Old Dec 15, 2007 | 02:48 PM
ya its a 04.5 quad cab shortbox
Old Dec 16, 2007 | 06:35 PM
anyone have an answer?
Old Dec 19, 2007 | 02:16 AM
bsj04's Avatar
also feel around the drive line after sa good drive to see if anything in hotter than it should be. could just be a u-joint. since you have a short bed you dont have a carrier bearing.
Old Dec 19, 2007 | 06:17 AM
deerefarm06's Avatar
Ive got just about the same exact thing going on with my truck. Its at the dealer now getting diagnosed. I'll post up the outcome.
Old Dec 19, 2007 | 07:19 AM
Tocapet's Avatar
I used to have a '65 Pontiac that did that. Turns out it was the nut that holds the yoke on the diff. It got loose and allowed the pinion to move back and forth. On acceleration, it would move forward. On deceleration, it would move back and rub against the carrier. Tightening the nut stopped it, but it kept getting loose.
Old Dec 19, 2007 | 10:29 AM
Dealer called and said it was the driver side front U-Joint. $390 installed + tax. The only thing different between my noise and yours was, mine does it at almost any speed, at certain points it will go away, but no set pattern, it was sparratic.
Old Dec 20, 2007 | 02:17 AM
bsj04's Avatar
no warranty?
Old Dec 21, 2007 | 08:24 PM
k thanks i will get those things checked out
Old Dec 21, 2007 | 08:39 PM
Dynocon's Avatar
Mine did the same thing, it was worse when cold. I thought it was the rear end. Then I noticed that the rear outside brakes were worn, it was a howl not a typical high pitch squeal. Canged the brakes and the howl went away.
Old Dec 22, 2007 | 08:13 AM
Originally Posted by bsj04
no warranty?
No, im at 40K so my bump to bump is out and I guess they dont consider the front axle components as part of the "Drivetrain"
Oh and BTW, the u-joint wasnt the problem, the dealer doesnt know what is wrong with it. But, the ujoint was very bad and needed to be replaced regardless.
shaft
49
May 27, 2004 03:56 AM
TurboTed
Apr 20, 2004 03:54 PM
abb
Sep 13, 2003 01:13 PM
Dodgezilla
May 6, 2003 06:50 AM
TommysBlue
Oct 21, 2002 10:27 AM
