How tough are the AAM axles?
Old May 16, 2007 | 08:48 PM
wreedCTD's Avatar
Just how tough are the AAM axles? I have always heard good things about Dana but never AAM. Isnt our rear axle the same axle behind the Duramax too?
Old May 16, 2007 | 09:07 PM
WUnderwood's Avatar
PourinDiesel has a bunch of sled hooks on his factory axles, without breaking. I think they are pretty strong
Old May 16, 2007 | 09:20 PM
rich's Avatar
broke a dana 80 havent broke an AAM one yet
Old May 16, 2007 | 09:53 PM
DieselDo's Avatar
The chevy is a locker,much better than my limited slip.
Old May 16, 2007 | 10:50 PM
mrblond's Avatar
good question, I read that they are the same company that made the 14bolt corp for chevy, and I think thats good if true?
Old May 17, 2007 | 11:23 AM
PG4x4's Avatar
Bent the front AAM and i think the front end might of come off the ground like a 1ft if that. Also bent a rear AAM in a ford f150.
Old May 17, 2007 | 12:45 PM
ptgarcia's Avatar
These are stout axles. If you break one you have to be doing some serious stuff. Bending the front while jumping is understandable with 1000 lbs of engine coming down on it!
Old May 17, 2007 | 02:17 PM
bob4x4's Avatar
The Dana 60 can take way more air time than the AAM I know first hand with both.
Bob
Old May 17, 2007 | 11:57 PM
XLR8R's Avatar
Really?
The AAMs are physically so much larger than the Danas... seems as though the newer axle tubes/differential housings would be concomitantly stronger.
Old May 18, 2007 | 12:00 AM
Luvnacumns's Avatar
Originally Posted by XLR8R
Really?
You reading my mind again!!!
X2!!
Old May 18, 2007 | 12:11 AM
SundayMoney's Avatar
The AAMs are rated for almost 11K lbs.
Old May 18, 2007 | 04:46 AM
PourinDiesel's Avatar
AAM's in stock form are MUCh superior to Dana's in so many ways.
30+hooks and still smokin'
Old May 18, 2007 | 06:00 AM
mainer's Avatar
aams have a locker?
are you refering to the "govlock" or w/e its called, i believe that is just a limited slip.
info from my dmax friend says that the "govlocks" hold up great as long as you dont do donuts.... keep them burning in a straight line and they'll last forever.
Old May 18, 2007 | 06:13 AM
jrsmokestacks's Avatar
Just lost a hub seal on the rear at 50,8xx miles. Broke 2 front u-joints so far and 2 front pinion seals. Truck sees nothing past a grassy field or gravel road but does snow plow alot. I'm still pleased with them though, no real broken parts yet.
Old May 18, 2007 | 08:35 AM
mule3010's Avatar
The only way a dana could be stonger is if they use far superior metals.(they don't) the sheer increase in mass in the 11.5 AAM over the dana along with it's higher rating would all indicate that it would hold more.
Joe
