how too check for codes on 06
Old May 17, 2006 | 02:03 AM
ramtd02's Avatar
on my 2nd gen we had the old 3 key turn trick....how can you check for codes yourself on an 06....or did they take that feature away from us?
Old May 17, 2006 | 05:11 AM
TexasCTD's Avatar
I don't have an 06, but I recall somebody else on here mentioning it is the same. Just turn the key 3 times. Same for all 3rd gens I think.
Old May 17, 2006 | 11:35 AM
Foxborough's Avatar
The 3 key trick works on my 06. It takes a little trial a few times, I know it's operator error.
Old May 17, 2006 | 07:11 PM
burlhall's Avatar
That feature is not available on the 06.
Old May 18, 2006 | 07:46 AM
Foxborough's Avatar
It worked on my 06. Check engine light came on, checked codes. The first was battery temp rational, a few months later the Intake sensor rationality. They both went away in a day.
Old May 18, 2006 | 07:59 AM
xyzer's Avatar
Ditto here!
Old May 19, 2006 | 11:16 AM
SkyHarborCowboy's Avatar
I tried this in my 05 and it wouldnt work. Can you explain the technique in detail. Do you turn the key all the way off when you cycle the ignition switch or just go half way so the odometer can still be read? Do you turn it all the way on or just to the half way point. How long should you keep it in the on position and how long to you have to keep it in the off position for each cycle?
Joe
Old May 19, 2006 | 11:51 AM
blord's Avatar
Did my new 06 last night for the 1st time. Went all the way off each time and did it fairly quickly. On the 3rd time just leave it in the ON position. Your odometer readout changes to" ------ ". Mine kept that display for a while and then showed "done". I assume if it had found codes it would have displayed them. After it shows "done", it switches back to the odometer display after a few seconds.
Old May 20, 2006 | 08:08 AM
Mopard's Avatar
just did mine right now and it worked! haha, I'd tried it before with no success ... was told '06 didn't work. You have to turn it on and off 3 times quickly, before the bulb check starts running each time, then as noted, leave it ON the 3rd time. I just got the "DONE" ... no codes. I was hoping to see a code that read "Tranny shifts like crap... Please Fix" ... haha, but no such luck
Old May 20, 2006 | 10:34 AM
Foxborough's Avatar
I liked that. I sure does some interesting shifting empty. But it sure gets down to business when I put my #6000 boat behind it, I can't complain. I wanted a hand shaker but the wife had a vote also. Saves me from shopping when we are out of town on weekends.
madhat
68
Oct 25, 2015 08:25 AM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
cheff
Jan 23, 2006 09:44 AM
