how long should U-Joints Last?
Old Aug 22, 2007 | 09:24 PM
Wild04.5's Avatar
how long should the Rear U-joints Last?
i have 48K on the clock and just had to have the middle rear U-joint replaced..
is this common? Dust just fell out of the caps when he removed it.. Very shot.
should *I* have the other 2 U-joints replaced on the rear driveshaft?
Old Aug 23, 2007 | 07:27 AM
booman70's Avatar
I did my front driveshaft @ about 39k one ujoint was bad but while I had it out I did all three to have greasable ones in there but I do alot of plowing. If its back in the truck then I wouldnt bother until one gives you a problem. Doin front axle ujoints now @ 41K but I never did rears.
Old Aug 23, 2007 | 07:42 AM
Pooter's Avatar
I had one go out on the rear ds two weeks ago @ 47k miles...
I need to do the front one too, before I get vibrations like the last one, but havent had the time to pull it out and jack with it again...
Old Aug 23, 2007 | 09:43 AM
DmaxEter's Avatar
My rears made it 42,000 before I heard the squeaking going on. Sure enough, one cap was dry! Now I got some greasable precisions in it and no worries.
Old Aug 23, 2007 | 10:00 AM
dodgezilla04's Avatar
i lost mine at 24k
Old Aug 23, 2007 | 10:08 AM
05mxdiesel's Avatar
Lost the rear middle u-joint at 47k. Decided to buy all of them at once from rockauto which are precision greasable joints. I did all three in the rear at the same time since the d/s was out. The rest will get replaced as they run out of grease and burn up.
madhat
Jan 11, 2015 12:05 PM
J-man
16
Jul 7, 2008 05:28 PM
ShaneCTD600
14
Apr 15, 2007 11:42 PM
Hoss
Dec 15, 2006 09:37 PM
krock
15
Jul 28, 2005 11:43 PM
