How Do You Know?
Old Aug 29, 2006 | 05:31 PM
robertc82's Avatar
How Do You Know?
I have a 2005 2500 4x4 with a 6-speed, how do I know what gear ratio, and trans. I have? How can I post a pic. with my threads? thanks for your help!
Robert
Old Aug 29, 2006 | 06:04 PM
Casket Man's Avatar
Inserting a picture, you first need to submit pictures in your gallery provided by this website.
Then go to your gallery and copy the IMG then go to post a message and click the little yellow box above your message text (insert image) and paste the IMG and there you have it.
Also please fill out the signature of your truck, so we all know what you have when you ask your questions!
Old Aug 29, 2006 | 06:16 PM
trik396's Avatar
Gear ratio can be easy to figure out. You need to jack up the rearend, get the rear tires off the ground and put some jackstands under the rear end. Make sure the front wheels are chocked somehow. Put your trans in neutral. You can put a mark on your driveshaft with a small piece of tape, maybe 3", running lengthwise of the shaft. This is the starting point. Then you want to turn your rear wheels by hand while looking and counting the number of times your driveshaft makes a complete revolution as you make one full revolution of your rear tire. When your rear tire has made one complete turn and you've counted the times the shaft has turned you'll know. If it turns more than 4 times, you've got the 4.10 to 1 rear gear. If it's less than 4, then its most likely the 3.73. This is the easiest way I know of, aside from looking at your window sticker...
Old Aug 29, 2006 | 06:22 PM
robertc82's Avatar
My window sticker says 11.5 rear axle thats all I seen
Old Aug 29, 2006 | 06:31 PM
Duallydog's Avatar
Ok you could go about it the hard way or what rpm are you at running 70? If you run around 2200 you either have 4.10s with the NV-5600 or 3.73 with the G-56. To tell the difference between the two transmissions is where the reverse is. If it is up and to the right it's the NV. Down and to the left is G-56
Old Aug 29, 2006 | 06:33 PM
philobeddo's Avatar
get your VIN # and call a dealer, service dept can look it up and tell you what gear ratio you have.
Old Aug 29, 2006 | 06:46 PM
CTDinMT's Avatar
Did you look in your glove box? In mine there's a sticker with the gear ratio on it. You definately have an 11.5" rear axle.
Old Aug 30, 2006 | 06:08 AM
TexasCTD's Avatar
Robert
The 05 trucks have the G56 6 speed and they only come with the 3.73 gears. So you have 3.73s. The G56 is already geared so low that 4.10s would be ridiculously low geared.
If your truck was an 04.5 or before it would have the NV5600 6 speed and they come with either a 3.73 or 4.10s.
The automatics can come with either gear ratio also for all 3rd gens.
Old Aug 30, 2006 | 06:11 AM
TexasCTD's Avatar
To post a pic.........go to your gallery and click on the pic you want to post. Now look down at the bottom and you will see a line that says "UBBcode". Right click and highlight that whole line and save it. Go to the thread you want to post it in.........and right click and paste it. Voila.
JKM
Jul 3, 2005 04:59 PM
welder27
Apr 25, 2004 12:27 AM
Hoss
Jan 24, 2004 08:13 PM
TPilaske
Apr 3, 2003 04:18 PM
