How do i adjust the idle on a '03 cummins?
Old Mar 20, 2008 | 11:27 PM
masonpauls's Avatar
Exclamation How do i adjust the idle on a '03 cummins?
Curious how to adjust the idle on a '03 2500 dodge cummins, and where should it be idling? 750-800 rpm? Any help would be great.
Old Mar 20, 2008 | 11:35 PM
RCW's Avatar
RCW
The common rail in the 03 should be adjusted with the dealer shooting a new load so it does not conflict with the PCM set points for the electronic transmission controls if it is an automatic. If you are a standard with A/C, again the dealer should program it for you to avoid A/C conflicts in the PCM.
It will only be a couple hundred to have it done.
The days of twisting a wrench are pretty much gone.
Old Mar 21, 2008 | 12:16 PM
masonpauls's Avatar
thanks
thanks for the info rcw.
Big Deezul
31
Mar 14, 2022 12:41 PM
moovintarget
Jul 5, 2010 06:17 PM
VADSLRAM
Oct 20, 2006 08:27 AM
Ram of Steel
Jun 15, 2006 10:05 AM
pred
Jun 2, 2006 10:52 PM
