idle will not adjust
Old Jun 13, 2006 | 12:28 AM
Ram of Steel's Avatar
After installing the 3K GSK and replacing the #5 with a #10 plate, my idle jumped up by approximately 150-200 RPM. I have tried adjusting it down with no luck.
I am using the 6mm bolt with the jam nut on the bottom to adjust the idle???
I can get it to either not idle if I adjust it too far but otherwise the idle will not drop below 750-800 RPM.
Any information would be deeply appreciated.
Thanks, Don
Old Jun 13, 2006 | 07:12 AM
berner's Avatar
Your gov spring retainers might be a click or two too tight. Your idle should be 750-800 in neutral with the A/C on. It'll start better if you set it there.
BTW, the idle stop bolt gets a groove worn in the top that can make adjusting the idle a bit touchy.
Old Jun 13, 2006 | 04:33 PM
TxDiesel007's Avatar
Originally Posted by Ram of Steel
After installing the 3K GSK and replaceing the #5 with a #10 plate, my idle jumped up by approximately 150-200 RPM. I have tried adjusting it down with no luck.
Thanks, Don
Hmm
i think the actual size is a 10 mm bolt with a 10 mm locknut at the bottom. If your idle will not come down anymore, then your springs are too tight, They should be at .55-.60 of an inch to fire up just fine. I would back them off a click or two at best. But why would u want it to idle at less than 750-800 rpms? As i recall, 800 is cummins spec for what these trucks should idle at ..
Rick
Old Jun 13, 2006 | 08:31 PM
I did set them two clicks tighter when they were installed. They were both at .025" Now they are at .045" I thought the idle was supposed to be lower on the manual shift? But I did not read the engine plate either
It does not start as easy with them set two clicks tighter.
The adjustment bolt has a 10mm head but it is a 6mm bolt. Thanks for the tidbit on the groove in the head of the bolt. I did check it, it's smooth.
Thanks for the help.
Don
Old Jun 14, 2006 | 11:12 AM
Don
Try them at .55
youll love it, and u wont have those famous hanging RPMS that occur if the springs are too tight...
Rick
Old Jun 14, 2006 | 08:09 PM
Since this is the first time I have replaced or adjusted the gov springs and basically still in the beginning learning stages of the Hi Perf diesel world, where would I measure the .55 that you mention.
I measured the difference between the top of the stud and the top of the adjuster nut. Stock configuration was .025" twenty five thousandths. After installing the new 3K GSK, I adjusted it down to where I had .045". The idle doesn't return as quickly as before and the idle is also higher than before. It is livable though. The engine feels a lot looser where it is now and with the new springs. That is probably to be expected??
If I measure .55 which to me is larger than 1/2", where will I be taking this measurement? Am I misunderstanding
Thanks, Don
Old Jun 14, 2006 | 09:28 PM
Thanks, Don
I meant .55 thousands of an inch
I took the measurement from where the governer spring retainer nut is dented for the screwdriver to the top of the governer stud. It worked well for me.. i took measurements on both sides of the stud nut to ensure consistency on both sets of springs.. Ive also done this before for the other 3 ive put in...
If your idle does not return as quickly as before and u want it to actually be brought back quicker, loosen the springs one click only, that should help. its a trial and error process, If the idle is a little higher its ok..
By looser you mean that it accelerates quicker? and the tach seems to rise quicker? that is the point of the GSK! it will make ur truck more fun to drive...
Rick
Old Jun 14, 2006 | 10:50 PM
Fueling around's Avatar
Originally Posted by TxDiesel007
Try them at .55
Rick
I have never set an auto pump that tight.
Old Jun 15, 2006 | 12:54 AM
I will back them off one click this weekend.
Old Jun 15, 2006 | 10:05 AM
12valve's Avatar
Thanks, Don
lower the idle to where you like it, and the rpms will come down quicker!
Big Deezul
31
Mar 14, 2022 12:41 PM
gomerpile
Jan 31, 2008 05:08 PM
jstrdiesel
Aug 22, 2007 03:47 PM
VADSLRAM
Oct 20, 2006 08:27 AM
pred
Jun 2, 2006 10:52 PM
