how to adjust high idle
Old Aug 21, 2007 | 01:17 PM
jstrdiesel's Avatar
how do you adjust the high idle?
Old Aug 21, 2007 | 05:20 PM
dieseldemon's Avatar
What year is your truck?
Old Aug 21, 2007 | 06:17 PM
Dr. Evil's Avatar
How to adjust idle speed???
http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
Of course, this is only for 12V's
Old Aug 21, 2007 | 07:04 PM
Hi idle is diff than std idle hi idle is the top engine speed that your engine can go to under no load it has a lock on it that depends on what year the truck is
it is called hi idle no load
Old Aug 22, 2007 | 08:42 AM
jstrdiesel's Avatar
high idle
1997 cpl 2174.
Old Aug 22, 2007 | 03:47 PM
Yours has a plastic lock on it and is not hard to remove Remove the lock and screw the limit screw in until you get the rpm you want DO NOT GO OVER 4000. See the picture the hi idle screw is the one with the large red plastic lock on it low idle is the one below the gov arm which you can not see in this picture.
Big Deezul
31
Mar 14, 2022 12:41 PM
kicker210
Dec 2, 2009 08:23 AM
gomerpile
Jan 31, 2008 05:08 PM
jmccart
Jun 12, 2007 02:12 PM
pred
Jun 2, 2006 10:52 PM
