How do I adjust the idle on '06 5.9L 24v Cummins
Old Jul 1, 2010 | 11:11 PM
moovintarget's Avatar
My idle in Park no AC is 500RPM. 5500 w/ AC. The engine sounds good and runs good, but the idle speed seems low. If memory serves me correct it should be about 700-800RPM. I know the earlier 12 valve engines had an idle screw adjustment. What about the 2006?
Old Jul 1, 2010 | 11:15 PM
madhat's Avatar
Administrator/Jarhead
I'm assuming that you meant 550 with the AC... I need to get me an AC like that if you're posting right...
Sorry, the idle is adjusted by the ECM.
Do you have any codes? Changed your fuel filter lately?
Old Jul 1, 2010 | 11:16 PM
bigwheels94's Avatar
You don't. Computer controlled. You have 1 of 2 problems. Computer problem, or tach problem. I'd photo-tach the engine to find out which.
Old Jul 1, 2010 | 11:40 PM
550 w AC 500 w/o AC. Fuel filters changed 2 days ago. Engine runs smooth. I have had similar problems on gasoline engines that were computer controlled. It was usually fixed by either replacing an emissions sensor or repairing a vacuum line.
What is the correct idle speed w and w/o AC?
Could low fuel pressure at idle from one of the pumps cause this?
Old Jul 2, 2010 | 10:22 AM
AH64ID's Avatar
I have heard of 06's having dash issues, so thats probably your problem... But like bigwheels said use a photo tach to verify.
Idle speed should be 750 regardless.
Old Jul 2, 2010 | 10:25 AM
CoastalDav's Avatar
There should be a sticker on the left side of the valve cover with all the info on the engine. On mine it says 750 RPM for Idle. Don't think the Cummins knows the A/C is on or if its hooked to anything when running.
Old Jul 2, 2010 | 08:14 PM
NickBeek's Avatar
The idle should be 750 unless you have had the ecm flashed and then it should be 800. There have been problems with the tach's on '06 trucks. Like has been said already confirm your actual idle speed before you go fixing anything.
Old Jul 5, 2010 | 09:57 AM
BigDiesels's Avatar
After verifying if your idle is in fact low, you can change the idle speed with AutoEnginuity scan software. It does seem odd that your idle would change on it's own though. If it sounds OK, it probably is your tach going out on you.
Old Jul 5, 2010 | 06:17 PM
Lost Lake's Avatar
Yup,
Mine idles at 500 also.
I think the tachs give out in the 06's, because I KNOW it isn't idling at 500 rpm's. That would be crazy.
Big Deezul
31
Mar 14, 2022 12:41 PM
Smokin'02
Feb 9, 2009 08:43 PM
masonpauls
Mar 21, 2008 12:16 PM
Ram of Steel
Jun 15, 2006 10:05 AM
pred
Jun 2, 2006 10:52 PM
