How to ( BALL JOINTS )
Old Aug 27, 2011 | 10:57 PM
  #151
blkt6's Avatar
Ball Joints
Can some body explain how to remove the brake caliper. I didnt understand about using the c-clamp.
I need new hubs and ball joints, and trying to do it myself
Thank you
Old Sep 15, 2011 | 12:16 PM
  #152
Dr. Smasher's Avatar
Well it's my turn to do this now!
So I'm gonna track this one.
Old Sep 28, 2011 | 09:14 AM
  #153
AMixon's Avatar
Just did this on my 3500.
Imagine how much easier this job would have been if the factory used .05 cents worth of Never-Seize? Oh, someone forgot to put in a Cotter-Pin on my driverside axle. Could this have been the reason for my ABS sensor 'chime' going off from time to time?
Thanks for starting this thread!
Old Sep 29, 2011 | 07:56 PM
  #154
03CTDCO's Avatar
Thats exactly what is happening to me now. Had new ball joints installed and the ABS light keeps coming on. Took it back in, they removed the sensors, cleaned them off, reinstalled everything and the ABS light is back on again.
Any ideas ?
Old Sep 30, 2011 | 12:25 PM
  #155
masterphreak's Avatar
Not sure if anyone has posted about this yet. I just used one of Snap-On's dodge hub removal tools when I did my passengers side. Was well worth the money, made the job very easy. When I did my drivers side last year I used the socket and extension method and split the socket like a banana peel. I felt much safer using this tool.
Here is a link to the tool on Snap-On's site
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Sep 30, 2011 | 01:59 PM
  #156
Unit44's Avatar
Question
So how do you use this tool?? back out the hub flange bolts a bit and push on this socket with the power steering??
Old Sep 30, 2011 | 02:04 PM
  #157
Yep, it is made to replace the socket for this procedure. It is a solid steel piece very durable.
  #158
Dr.Dizzle's Avatar
Here is a link demonstrating the procedure.
http://image.snapon.com/international/pdf/dhp1_npa.pdf
Old Sep 30, 2011 | 02:50 PM
  #159
Unit44's Avatar
Thumbs up
Thanks guys... I believe I will add this to the toolbox....
Old Oct 1, 2011 | 08:53 PM
  #160
leadvilleram's Avatar
I used this tool with an impact socket and 3 lb hammer to drive out the hub. I had to go back and forth from front bolts to rear bolts a few times, but successfully walked the hub out of the knuckle (without breaking anything). The idea of using the hydraulics to do this made me nervous for many reasons, though it seems many have had success. Just another way to skin this cat...
FYI, Quad 4x4 has a great site and lots of goodies. I installed their greaseable ball joints in my 3rd gen about a year ago, using their press and tools. I am surprised no one talks about them, or at least that I've seen. I used them for a front dana/driveshaft ohaul on my old 1st gen too. Top quality goods there.
Old Apr 3, 2012 | 09:02 AM
  #161
Shorts's Avatar
BUMP
(This isn't stickied is it?)
Old Apr 7, 2012 | 12:57 AM
  #162
My turn for this now.
I got the MOOG ones. Anyone with any experience with them?
Old Apr 7, 2012 | 08:17 AM
  #163
Nadir Point's Avatar
I was able to get the hubs out pretty easily using a small bottle jack to push on the bolts from behind when I did my axle joints a few weeks ago. It took a few wedges and spacers to get lined up right in various positions, but still seemed much more controllable and safer than the power steering or slide hammer methods.
Old Apr 18, 2012 | 10:47 PM
  #164
So no matter what I do I can't get the rotor off. Any tips or suggestions?
Old Apr 19, 2012 | 11:32 AM
  #165
I CANT GET THE ROTORS OFF!!!! :bang head
I have hit them with the BFH over and over as hard as I can and nothing has budged! I have tried putting and using a bottle jack in behind it and nothing happens.
Anyone have any tips, I am getting desperate at this point.
