high idle iusse
Old Feb 7, 2011 | 10:30 AM
winkdemon's Avatar
high idle iusse
hey guys
i have just put a 2003 crd cummins in a 2004 ford f-350 , and found that the engine is idling at 1150 rpm witch is about high setting , the pto is not active and the TPS is at 0 % ,,, the only thing i can found is the temp sensor is not reading right truck at running temp is says about -10 c ,, i have checked the wiring to the sensor ground is good and the sensor has 5 volts at it . i ordered a new sensor but have to wait for it ,,,, just wondering if you guys have had this iusse before
thanks for the help
Old Feb 7, 2011 | 02:24 PM
Sur5er's Avatar
If the temp sensor is telling the engine that it's -10F, then she will go into high idle on start-up, right?
Old Feb 8, 2011 | 03:40 PM
winkdemon's Avatar
ya it should ,,, but i put the new sensor in no change
Old Feb 8, 2011 | 05:12 PM
rockcrawler304's Avatar
Kind of a long shot but do you have access to another ECM? With a new temp sensor and no wiring problems, it almost sounds like it is an ECM issue.
Old Feb 8, 2011 | 07:34 PM
winkdemon's Avatar
thats what i was thinking but i only have new ecms . one foe 2005 ,2006 .2008
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
