high idle flash??
Old Oct 27, 2009 | 01:37 AM
  #31
annabelle's Avatar
Tell him it's there, they just need to enable it.........complain about low cabin temps.
Old Oct 27, 2009 | 06:04 AM
  #32
MassZJ's Avatar
or just print out post #21 and hand it to them
Old Oct 27, 2009 | 11:21 AM
  #33
Gregg#628's Avatar
Is that for the 06's as well?, I had read that and thought it was for 04's and earlier. Thank's
Old Oct 28, 2009 | 02:42 PM
  #34
Gregg#628's Avatar
UpDate for me: I Took my truck to MidWay Motors in Mcpherson ks. It was about an hr away. They new what to do. Now I just start the truck, turn on the cruise, then hold down the set and accell button and the same time and then let off. The engine go's from 700rpm to 1100rpm . While I was there he brought to my attention 2 recalls. One on the steering box and the other on hose clamps. Steering box was taken care of when lift and such were installed. The clamps have to be ordered. while I was in I had them install the block heater cord, yea it looked easy to install, but I don't get around as good as I used to. Anyway, I'm ready for winter as far as that go's. 411's, air lockers f&R and Dynatrac hubs the week of Nov. 11th. Then I'll really be ready for winter
Old Oct 28, 2009 | 06:51 PM
  #35
Spooler's Avatar
All you have to do is turn on the cruise and press the set button to activate the high idle. You press the Accell/decell button to make it go higher or lower.
Old Oct 29, 2009 | 12:54 PM
  #36
Gregg#628's Avatar
Mine only works as I decribed. I wander if there's dif flash codes. No matter, mine will idle up to 1100 RPM, that'll work
Old Oct 29, 2009 | 12:59 PM
  #37
no_6_oh_no's Avatar
Don't hold down the Accel button, just hit the set button with the cruise on and should idle up to 1100. Then you can use the Accel\Decel buttons to adjust up and down.
Old Oct 29, 2009 | 10:34 PM
  #38
annabelle's Avatar
I hit the cruise on button then the set button and then use the accelerate button to take it up to 1500 RPM.
Old Oct 31, 2009 | 10:45 AM
  #39
Gregg#628's Avatar
Thanks !! It works as you descibed
kicker210
Dec 2, 2009 08:23 AM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Nov 3, 2004 08:07 PM
blownaway
Feb 25, 2004 07:13 PM
Mechanos
32
Feb 1, 2004 02:30 PM
