Help Please
Old Jan 23, 2009 | 08:43 PM
Midnite Warrior's Avatar
Help Please
I had to pull my engine and replace it. The problem is that when I was trying to pull it out the valve cover was hitting my firewall and the oil pan was hitting my cross member. I have pulled many of engines in different vehicles but this one took the cake. I actually had to drop the oil pan and pick up tube. I don't want to do this with the new one. Any suggestions? I'm sure there's something I'm missing but can't figure it out.
Old Jan 23, 2009 | 08:48 PM
Totallyrad's Avatar
I know one of our local dealers have started lifting the cab to do an engine swap. They claim it knocks 4 hours off the time.
Old Jan 23, 2009 | 08:51 PM
I heard something like that. But what about the front fenders? Do I need to unbolt them from the cab or frame?
Old Jan 23, 2009 | 08:57 PM
Totallyrad's Avatar
I honestly cannot answer that. I didn't get to see one in process, it was just a discussion we were have in the service managers office.
Old Jan 24, 2009 | 09:16 AM
mini14's Avatar
i think its kinda like the 2nd gens where u have to pull the front off, rad support,rad,intercooler, looks to be the simplest way to go.
Old Jan 24, 2009 | 10:42 AM
I did all of that but it doesn't help with the oil pan wedging between the cross member and valve cover hitting the firewall. What it is when I pull it forward to clear the firewall the oil pan hits the cross member. So, I can't come forward anymore. therefore I can't pick the engine up anymore.
Old Jan 26, 2009 | 01:40 PM
SOhappy's Avatar
You sure it wasn't a Ford dealer?
(They get lots of practice...)
Old Jan 26, 2009 | 06:22 PM
Totallyrad's Avatar
Yep, I'm sure. You're right though, they should look like a NASCAR pit crew with all the opportunities they've had to practice.
Old Jan 26, 2009 | 07:54 PM
1-2-3's Avatar
Just a plain ole guy
Get and engine balancer. probably not the right name for it. Its a device with a lift point in the center and a cranck handle so you can change the balance point of your lift. Lift the weight off the mounts, then crank it till the block rolls forward and will allow the valve cover to clear, then lift the engine up, When the oil pan clears crank it back the other way and level it back up.
Like this, but maybe better quality then harbor frieght. It will be a heavy engine and HF stuff is kinda gimpy
Well, I can't find it at harbor frieght. Maybe someone can chime in with a link
Old Jan 28, 2009 | 08:17 PM
trik396's Avatar
Why are you trying to remove/install with the valve cover in place? Take it off and I bet you'll get the added inches of clearance you need.
Old Feb 7, 2009 | 12:44 AM
Actually had to raise the cab up about 6-8". Then it went without any problems.
Old Feb 7, 2009 | 03:14 PM
trik396's Avatar
Again, why? If you'd have pulled the cover and everything below it (injectors, rockers, etc) you'd would've been fine.
Old Feb 8, 2009 | 10:33 AM
dozer12216's Avatar
Just completed similar job. The cover and valve train off helps get out with the engine balancer. Getting back in was the killer. Had to remove crossmember and move manual tranny back 8 inches or so to get clutch stabed. The engine balancer and one person with sole responsibility of getting install angle sharp enough with valves and pushrods clearing cowl area.
We did think about raising body, but got offtrack due to number of supports (6), the brake plumbing, and unknown about fenders. The crossmember, driveshaft, and manual lever were perhaps a hour added.
Tell more about raising body???
jamesbfishin
Apr 16, 2016 11:32 AM
DHT
Apr 2, 2010 07:12 AM
SuperiorRam
Mar 15, 2007 03:10 AM
MoparRiggan
Jan 17, 2006 12:43 PM
Lary Ellis (Top)
May 21, 2003 10:16 AM
