help needed for dead 04
Old Dec 30, 2008 | 02:05 PM
rich's Avatar
no selinoid that i'm aware of have you tried to get codes that will help tell whats wrong with it
Old Dec 30, 2008 | 03:17 PM
mini14's Avatar
u look for a stuck fca...turn key to run not start u will hear rapid clicking if it is working correctly. if not r&r it or try cleaning it.
Old Dec 31, 2008 | 09:53 AM
madhat's Avatar
Administrator/Jarhead
Fuel control Actuator...
On the back of the CP-3. Note to self... tap the bolts before trying to remove them, or you'll eat up some T-25 bits...
Old Dec 31, 2008 | 10:43 AM
madhat's Avatar
I can't answer that one... I think that everything is internal.
Let me go look at the one that I have in the shed...
Old Dec 31, 2008 | 10:46 AM
madhat's Avatar
You might be able to see the plunger move through the 4 holes on the sides, but I'm not too terribly certain...
Old Jan 4, 2009 | 02:06 PM
tedwhazen's Avatar
I don't know if this will help but I have an 04 that just stopped on me three times. Towed to dealer who replaced in tank lift pump(twice) a rail pressure modulator(not sure if this is the right term) and a complete set of injectors and they could still not get fuel to the engine. After two weeks the technician dicovered a corroded ground wire that was installed when I had a factory wiring harness installed for my camper. That repaired and it's running as new with several new parts I did not need. Total bill was over $8000 and it cost me $192 for the diagnosis. Rest was on Chrysler.
Old Jan 23, 2009 | 10:17 PM
DENVERDODGE04's Avatar
well thats good news, remind me not to go to that freakin dealer, then again maybe thats why i don't go to dealers and do everything myself. You just can't trust anybody anymore
Old Jan 24, 2009 | 04:48 AM
RDyson's Avatar
And just a reminder, never "crack" any lines out of the injection pump on a commn rail. The pressures are at least 5k at idle--and up to 23k at WOT. It can be very dangerous if your hand is in the wrong place.
Randy
Old Jan 27, 2009 | 03:09 PM
madhat's Avatar
Sounds like you have some filtering issues...
bgoodwin
Mar 1, 2008 05:36 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
newtododge
Apr 25, 2006 10:42 PM
billygoat02
Dec 30, 2005 09:19 AM
