HELP! Code problem
Old Aug 15, 2007 | 10:22 PM
scott54's Avatar
HELP! Code problem
My new-to-me '03 235 HP 2500 with 107K threw a code today, out of the blue, a P 0628
which I understand to be a 'Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low' problem. However, the truck runs FINE. No hiccups, stutters, or anything else. Should I replace the pump anyway? Is there anything else it could be? Any chance of engine damage in the interim?
Old Aug 15, 2007 | 10:33 PM
vzdude's Avatar
DTR's 'Go to Guy'
This should get yo uall the info you need to be able to diagnose it!
Symptom:
P0628-LOW VOLTAGE DETECTED AT THE FUEL LIFT PUMP
When Monitored and Set Condition:
When Monitored: While the key is on.
Set Condition: The voltage detected on the Fuel Lift Pump is above a calibrated value for
a calibrated amount on time.
POSSIBLE CAUSES
LOOSE CONNECTION
GROUND CIRCUIT OPEN
LIFT PUMP SHORTED TO VOLTAGE
LIFT PUMP
ECM
TEST ACTION APPLICABILITY
1 With the DRBIIIt, in system test actuate the lift pump.
Does the lift pump run?
All
Yes ! Go To 2
No ! Go To 3
2 Lift pump actuation still running.
While the lift pump is running, wiggle the wiring harness and connectors throughout
the circuit.
Does this interrupt the pump operation?
All
Yes ! Repair the loose connection.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
No ! Go To 3
3 Disconnect the ECM harness connectors.
NOTE: Check connectors - Clean/repair as necessary.
Measure the resistance of the lift pump (K62) supply circuit between the ECM
harness connector and the lift pump harness connector.
Is the resistance less than 1 Ohms?
All
Yes ! Go To 4
No ! Test Complete.
192
DRIVEABILITY - DIESEL
4 Measure the resistance of the ground circuit between the lift pump connector and
battery negative.
All
Yes ! Go To 5
No ! Repair the open ground circuit.
5 Measure the voltage between the supply and ground circuits of the lift pump
connector.
Is the voltage greater than 1 volt?
All
Yes ! Repair the lift pump circuits shorted to voltage.
No ! Go To 6
6 Reconnect the ECM harness connectors.
Connect a jumper wire between the (K62) supply circuit and ground circuit of the lift
Turn the ignition on.
With the DRBIIIt, read DTCs.
Did DTC P0628 set?
All
Yes ! Replace the lift pump.
No ! Replace the ECM.
193
P0628-LOW VOLTAGE DETECTED AT THE FUEL LIFT PUMP — Continued
Red3quarter
Sep 9, 2012 05:25 PM
CODODGE2500MAN
Nov 5, 2009 06:17 PM
qcbullrdr
Oct 2, 2007 10:03 PM
CTD NUT
Apr 5, 2005 04:45 PM
