Aux. trans. cooler
Old Aug 15, 2007 | 10:23 PM
one tonne's Avatar
Aux. trans. cooler
I bought an aux. trans. cooler ( super cooler )for my 48re on my 05 and was talking to someone about it and he said not to use it because it would decrease the line pressure and possibly cause other problems. Can anybody confirm this?
Old Aug 15, 2007 | 11:04 PM
no_6_oh_no's Avatar
I have been advised by several transmission builders that adding on to the factory transmission cooling system is asking for trouble. The return flow from the cooler is lube oil and adding any restrictions in the form of more tubing and coolers will cut the lube flow and starve parts of the transmission. Evidently the system is sized with very little over capacity to play with.
The stock trans cooling system is pretty robust, but, if extra cooling is wanted or needed a stand alone pump that draws from the pan and circulates thru the aux cooler is the recommended setup.
Old Aug 15, 2007 | 11:07 PM
Jeff K's Avatar
I have the super cooler on my auto and have had no problems
mruhlig77
Aug 26, 2007 05:16 AM
one tonne
Aug 15, 2007 10:29 PM
Mike T.
Jul 9, 2006 07:31 PM
goodtyms
May 16, 2006 08:48 PM
bigredbrick
Sep 24, 2003 11:46 PM
