Heads up on low battery!!!!
Old Dec 9, 2015 | 07:15 AM
EricArrow's Avatar
So I've been having an issue with the 2nd gear search in my 2007 5.9. I was resolved to changing the solenoid in the valve body since that seemed to be a common solution. Well the other day when I had a scanner hooked up the truck struggled a bit to restart. So over the weekend I decided to install two new batteries. When I was doing this I noticed the one battery had leaked up a bit on the cable connector so I cleaned it up and installed the new ones.
Guess what??...Second gear search is gone!! Truck seems to run quite a bit better also. Now realize the truck started fine every time before save for that one time. So if you are having an issue with a 2nd gear search I highly recommend checking battery voltage and condition of the batteries first.
Old Dec 11, 2015 | 10:00 PM
RamDodgeSam's Avatar
2nd gear search ... are you talking about the transmission slipping until engaging into 2nd gear?
Old Dec 12, 2015 | 09:53 PM
BlackPuff_Gone's Avatar
I made the same observation when I changed batteries two weeks ago. Also getting about a mile more per gallon of fuel.
Old Dec 13, 2015 | 06:14 PM
EricArrow's Avatar
That surging going from first to second
Old Feb 8, 2016 | 11:06 PM
fatpete's Avatar
Does anyone have an explanation of why old batteries could cause these things?
Old Feb 10, 2016 | 01:23 PM
steelblitzkrieg's Avatar
DTR Detective
My guess, it wasn't the batteries, when the batteries start to weaken you lose accessories such as radio.
What I think happened is when you changed the batteries it caused the PC to lose it's memory which forces the PC to relearn your driving habits in regards to shifting/throttle position, etc. I bet it will return before too long.
Old Feb 20, 2016 | 10:28 PM
Yep, you called it. Mine is back to its old tricks
Old Feb 22, 2016 | 03:53 PM
DTR Detective
Sorry to hear/read that.
Rancher99
Apr 18, 2011 09:46 AM
jesussaves
Nov 7, 2010 06:55 AM
EdmontonCanada
Oct 10, 2008 11:37 AM
taildragger
38
Dec 19, 2006 09:49 AM
planejane
Aug 23, 2004 03:17 PM
