Truck dies after pull
Old Feb 20, 2016 | 03:06 PM
Clff's Avatar
Hey guys, need some help with a 2004 Dodge Cummins, When its warm outside and I am pulling a trailer and need to pull over and stop for whatever reason, it dies and I end up having to sit there for about an hour before it will start again, it turns over fine when I am trying to start it but it just wont start. I have changed the fuel filter twice and nothing seems to help. Checking to see if anyone has had this problem also. I appreciate any help from you guys.
Thanks Cliff
Old Feb 22, 2016 | 04:30 PM
Clff's Avatar
Can anyone please help with problem?
Old Feb 22, 2016 | 06:02 PM
gcssr's Avatar
what lift pump do u have, on the filter housing or in tank, place a piece of hose over the filter drain tube place in a bucket, open drain valve see if lift pump is putting out, bump starter switch "do not start " see if pump is putting out
Old Feb 22, 2016 | 06:11 PM
Clff's Avatar
Thank for the reply! the lift pump is in the tank.
Old Feb 22, 2016 | 06:21 PM
Clff's Avatar
What pressure should the lift pump put out?
Old Feb 22, 2016 | 07:35 PM
Mexstan's Avatar
What pressure do you have and where are you measuring it.
Taking a shot in the dark here, but maybe remove the pipe from the pressure relief valve on the fuel rail and see if any fuel comes out when it is cranking. Or temporarily cap it off and try to start it. Don't run it with the cap on.
RamDodgeSam
Oct 12, 2015 08:39 PM
vintovka
Apr 30, 2012 12:38 PM
90 power ram
Oct 6, 2011 08:04 PM
92smokin blacky
Sep 14, 2011 08:44 PM
Bueller
Jul 8, 2006 10:47 AM
