Has anyone heard this one??
Old Sep 26, 2011 | 07:54 AM
regert's Avatar
I tried to search it but cant seem to find anything, I was talking to a tranny shop and he told me that there was a TSB at Dodge for tranny shifting issuses. The altenator puts out a signal that can make the tranny shift funny ei if your cruzin down the road and let off the gas a little the truck will kick back and forth a little, like it is going in and out of lock up converter.
Has anyone heard of this issue?
Thanks.
Old Sep 26, 2011 | 09:57 AM
no_6_oh_no's Avatar
That is a typical problem with the 2nd gens.
Its possible for a bad alternator to cause all sorts of issues in a CR for sure but not specifically transmission. Its also possible for a bad battery or scuffed wire in the harness to cause the same issues.
Are you having a problem like this or ????
Old Sep 26, 2011 | 10:06 AM
regert's Avatar
I'm having issue of when I get on the throttle and then get off it and coast it seems like the truck serges back and forth but the rpm's dont change.
Old Sep 26, 2011 | 05:33 PM
retirednak's Avatar
Genos garage sells a APPS NOISE ISOLATOR that should take care of your problem.
Old Sep 26, 2011 | 09:12 PM
no_6_oh_no's Avatar
Need info on your truck, year, trans, any mods.
Does it happen every time you let off the throttle or ??
Does it happen in OD, drive or both? What speeds?
Any other symptoms?
Old Sep 27, 2011 | 07:44 AM
regert's Avatar
The truck is a 05 CTD quad cab 4x4 48re, when I'm crusing at 110-120km/h (60-70mph) in OD, if I drive faster it wont do it only around those speeds. I have 4" cat back and a Dr.prformance 3, the truck has 306258KM on it. I have codes p0633, p0602, p0483, p0243, p0480.
Today I noticed that the rpm's were jumping a couple hundered rpm's everytime it jerked.
Old Sep 27, 2011 | 08:14 AM
no_6_oh_no's Avatar
Remove the Dr P and try to get those codes cleared. With the ones you have plus the power mod its hard to tell what is going on.
Old Sep 27, 2011 | 08:34 AM
regert's Avatar
It was doing it before the Dr. was installed. I guess not a good Dr. since it isn't fixed......LOL.
I'm going to call the dealer and see if they can flash the computer and go from there, I hope it isn't the tranny the truck runs mint.
M1Lover
Sep 24, 2009 09:41 PM
scarecrow
Jul 18, 2005 08:49 PM
jlells01
Feb 28, 2005 10:30 PM
ArcticWolf
Dec 27, 2004 10:02 AM
halerazor
Nov 27, 2004 08:09 PM
