Hanging RPM problem
Hanging RPM problem
stock 04.5 ....problem with hanging rpm for about 1-3 seconds before it comes back down. seems to be the same under a load or in netural.
Heard some ideas of cp3.. what else can I check.. thanks
myne did the same thing around 1200 rpm. turn out it was an bummed injector.. does it idle rough sometimes? just something to consider..if i would get on the gas pedal it and then let off it would keep moving for a second or two. girlfriend found that one out for me just about ran through the garage in the winter time
I may be way off by this one, but mine does the same thing. I think it just dumps so much fuel it just hangs there till it burns and the boost then comes back down. kinda like a run away engine that stops.
Correct me if i am wrong thou.
Mine does the same thing usually when you stand on it hard and then let out of it. Thought that it might be dumping lots of fuel in like always_lost said, or that it was reading the release of the pedal fast enough.
06 mega, edge att, magnaflow 5"
44's n 454
Apr 8, 2008 10:42 PM
Cowboy_Customs
Apr 19, 2006 12:15 PM
fishin fever
Feb 22, 2004 08:32 PM
