Got a tapper
Old Apr 30, 2010 | 07:03 PM
bishgeo's Avatar
Got a tapper
04 I just picked up has a tapping noise when you start it for about 30 sec.Hoped oil change would fix it did not .Amsoil 5w40 and motorkote still there.Sounds like a lifter pumping up.
Old Apr 30, 2010 | 07:10 PM
1985cucv's Avatar
check your oil for fuel you could have an injector stuck
Old Apr 30, 2010 | 08:26 PM
C/PRD/'s Avatar
X2 on the injector, Id seafoam it. My 03 did the same thing, right or wrong I ran a quart and a half per tank of 2 stroke oil in it till I traded it on my 06. The oil killed the ticking altogether.
Old Apr 30, 2010 | 09:23 PM
bishgeo's Avatar
Seafoam in fuel or oil.?? Any body try hot shot secret.?? Are injectors covered under cummins 100,000 mile waranty or factor.
Old Apr 30, 2010 | 09:38 PM
Dr.Dizzle's Avatar
This thread should help you determine if Hot Shot Secret is worthwhile.
https://www.dieseltruckresource.com/...ot+shot+secret
Old Apr 30, 2010 | 09:45 PM
C/PRD/'s Avatar
first tank one can seafoam, next tank two stroke. No need in the crank case. But that warranty is 5yr, 100k isnt it? What was your trucks in service date?
Old May 1, 2010 | 08:58 AM
Spooler's Avatar
If it is a slight ticking it is the air bleeding out of the injection system. No need to worry. It's fine.
Old May 1, 2010 | 09:23 AM
bishgeo's Avatar
I have howes meaner power cleaner,motorkote fuel conditioner and 2 stroke in it.I think cummins waranty is miles regardless of age.It sounds like an old chevy 350 waitin for the lifter to oil up.It runs great no fuel smell in old oil.The only odd thing is when you rev it up the rpm's stutter when they fall.Picked this rig up for my daughter coming home from iraq hope I did't get a turd.!
Old May 1, 2010 | 02:19 PM
Spooler's Avatar
Very common issue, doubt you got a junker. I would hook up something heavy and go run it hard for about an hour or so. It will run much better. No real need to put all the junk in the fuel system. Good old clean #2 is all you need and some good towing every other month.
jkarner
Apr 2, 2012 07:48 PM
Dale M
Mar 5, 2011 03:40 PM
bhoff1175
Jun 7, 2006 10:19 PM
Begle1
Jul 13, 2005 04:13 PM
crankbait
Feb 14, 2003 04:31 PM
