Got my 04 CTD today!
Old May 4, 2009 | 05:10 PM
tndiesel's Avatar
I'll post pics later but I got the truck and I love it! Tranny fluid looks clean and new, oil is full but I will change it because I just want to. I briefly looked under the truck and didn't see the oil filter! Where is that dang thing? It's a 4wd which I've never owned so I will need direction about that. The back differential looks dry but I will take pics of the front one and let y'all tell me what you think. What gear oil should I run in the front and back? How many grease fittings does this 04 2500 4wd have? I have tons more questions but will stop with these for now. Thanks!!!
Old May 4, 2009 | 05:13 PM
mikmaze's Avatar
congrats, now look on the drivers side of the plastic "valve cover" and find the hp rating for the truck, 305 ya got an 04 best mpg possible with that one, 325 hp, its an 04.5, smarty is your key to happiness
Old May 4, 2009 | 06:33 PM
tndiesel's Avatar
It says 305 HP at 2900 RPM. That seems pretty good to me in the HP rating. It's a step up from my 97 F-350 7.3.
Old May 4, 2009 | 06:35 PM
mikmaze's Avatar
good deal, you will be happy with the mpg you get out of it, but be clear in telling folks later on that it is an 04/ 305 motor so you get the right parts as many of them do not interchange.
Old May 4, 2009 | 07:20 PM
D45's Avatar
D45
You will love the early 2004 305/555 motor......welcome!
Old May 4, 2009 | 08:49 PM
tndiesel's Avatar
What is the 555? Is that what you can jack the HP up to if you want to?
Old May 4, 2009 | 08:53 PM
Det 1's Avatar
555 is the ft. lbs. of torque produced at the rpm's indicated.
Old May 4, 2009 | 10:17 PM
nelrod's Avatar
Yep, you got a good one. If I had it to do over, I would probably get an 04 like yours instead of my 06. Congratulations!!!! How many miles does she have? Don't forget to post up some pics.
Old May 4, 2009 | 10:32 PM
BigDave12768's Avatar
Fuel Filter is on other side of motor near the Master cylender. Gota use a 1 1/8 (could be wrong) socket with a swivel and at least 8 inch extension to make your life easy to change it. Just slide the yellow tab to other side and fuel will drain down by the Axle. Just follow the drain tube. Then just unscrew cap. Its just plastic so it comes off easy. Then just pop it off the cap. replace O ring and clip in new filter. Whats the 8th Digit of vin? I think they only have 3 grease fittings
Old May 5, 2009 | 01:48 AM
madhat's Avatar
Administrator/Jarhead
Oil filter is on the passenger side, front of the motor.
The only difference... they might have installed a remote bypass oil filter, so find where the oil filter should be, if it is missing, look for lines coming from it and follow them.
Old May 5, 2009 | 01:59 AM
Dodgefan01's Avatar
Where's these PICS?!?!
Congrats on the new buy, ENJOY!
Old May 5, 2009 | 07:09 AM
tndiesel's Avatar
The 8th digit of the VIN # is C. Does this truck have a "wait to start" display like my old 97 Ford 7.3? I haven't seen it pop up so I figured it doesn't.
Old May 5, 2009 | 10:12 AM
Silverram03's Avatar
Yes it does. It looks like a squiggly little yellow line in the middle of your bottom gauge cluster. Enjoy your truck I bought the first 03 305/555 at my dealership and have been in love ever since with my truck.
Greg
Old May 5, 2009 | 10:14 AM
billie's Avatar
"Wait to start" is a little coily symbol center on the display.
Old May 7, 2009 | 08:02 AM
Dodgefan01's Avatar
It prob. wont' come on until LATE winter for you down there.
Dale M
Mar 5, 2011 03:40 PM
bhoff1175
Jun 7, 2006 10:19 PM
Cartman
15
Aug 8, 2005 04:45 PM
Begle1
Jul 13, 2005 04:13 PM
Gypsyman
Aug 27, 2004 04:32 PM
