Go Ahead and Laugh now
"Boost" is not read directly off the MAP sensor, voltages are read and converted to boost so there is always going to be some sort of calculation involved.
Well if it reads barometric pressure then it would need a baseline pressure reading to calculate boost. That reading would change according to weather and altitude.
My understanding is the mappings for boost, rpm, etc, are simple lookup tables where a reading equals a number and extrapolation is used to find non-existent values. Not sure that info is available outside the engineering departments though.
When all this is said and done, the bottom line is that an oiled filter WILL slowly coat the first IAT sensor and the inside of the intake tube. With the new dry filters (like AEM) why would anyone still run an oiled filter?
I had an oiled filter and in 5000 miles it was coating my sensor and tube with a fine brown grime and causing the sensor to read erraticly.
I switched to the AEM dryflow and in the next 20000 miles no more grime.
Ditch the dino filter!
If you over-oil any filter you're going to have that problem. The key is get a good quality filter (NOT K&N) and don't over-oil it.
Bowser50
30
Feb 4, 2009 04:02 PM
jododo
Mar 4, 2008 03:41 PM
jododo
Feb 26, 2008 08:30 AM
natlchamp2k4
Jul 6, 2006 09:49 PM
