?gears?
Old Jan 21, 2009 | 09:05 PM
DENVERDODGE04's Avatar
?gears?
What should it cost to do gears front and rear, on an 04 dodge 2500? Anyone?
Old Jan 21, 2009 | 09:08 PM
rich's Avatar
i would say at 900 just for the gears if i remebr the price been about a year since i priced them
Old Jan 21, 2009 | 09:09 PM
is that to put them in too, or just for the gears themselves?
Old Jan 21, 2009 | 09:12 PM
rich's Avatar
like i said if i remeber right it was about 375 or 450 per set just for the gears could be wrong and it maybe lower now. that was about a year or 2 ago when they just came out with 342's
Old Jan 21, 2009 | 10:13 PM
OOPS's Avatar
Randy’s R&P has the gears for around $300.00 per diff, then you will need set-up kits that range from $70.00-$300.00 depending what you get. Then you have to find someone to do the install, which the price can vary, from installer to installer. The last time I had one set-up for my rock crawler I supplied the parts and the set-up was $175.00. That was on a drop out third that I pulled and took into the shop.
Old Jan 22, 2009 | 03:14 AM
Hounddog's Avatar
I bet a minumum of 5 to 6 hours labor per axel.$400 to $600 labor per axel.
Old Jan 22, 2009 | 02:58 PM
Ram Daddy's Avatar
....and definately DON`T go with the cheapest guy , that says he can do them in his garage.
I`ve had many gear swaps in the past , and some turned out better than others. The last Dakota I had , I swapped out some paint work ,for a gear swap, with our mech. we used...and he did such a bad job , I had to have them re-done by someone else that was more exp. in gears.
I`d say at least 400 each.
Old Jan 22, 2009 | 03:11 PM
carbuff415's Avatar
x2 on not going with the cheapest guy. Go with the most patient perfectionist you can find & afford.
Old Jan 22, 2009 | 04:53 PM
cbrahs's Avatar
book time on front is 6.7
book time on rear is 3.7
Old Jan 24, 2009 | 10:25 AM
TAS05CTD610's Avatar
What's funny was when I looked up the 4.10's at dodgeparts, the rear was like 400, but it said Ring & Pinion gear set (includes ring and pinion, bearings, seals) so it sounds like it comes with everything to swap over?? The front said ring and pinion? When it comes time for mine, going to find a good buddy and have him set everything. Changing them and all isnt' that bad, and if your bearings, seals are good should be all set (I'd do seals anyway) but again bearings should be fine if your low millage. I'm at 35,000 problably wouldn't change them if there good.
BigJohnston
20
Jul 14, 2019 10:58 AM
Roarinbear
Dec 27, 2009 09:44 PM
93beater
Feb 28, 2007 09:28 AM
Turbodude
Jan 4, 2006 09:13 PM
walexa
30
Apr 8, 2005 10:26 AM
