G56 Reverse Problems
Old Jan 16, 2017 | 03:01 PM
fattboy123456's Avatar
Hello every one I have a g56 Issue that I cant seem to find on forums I can get it into Reverse no problem but when I let the clutch out I get nothing all 6 other gears are fine.
On all the google searchers I have done its issues getting it into gear but nothing with it engaging
2007 Dodge ram 3500 5.9 Diesel
G56 6 speed manual
2wd
Old Jan 16, 2017 | 04:56 PM
Omg i didnt know that what a great sugestion your so help full............
Old Jan 16, 2017 | 06:21 PM
Got any more help full advise like a Turbo Delete kit?
I could use some helpfull info on that and you seem just like the guy
Old Jan 17, 2017 | 12:31 PM
Danderson's Avatar
Call Standard Transmission. They know your trans inside and out.
Standard Transmission & Gear | Tremec - Borg Warner - New Venture - Getrag, Cummins, 4 speed transmission, 5 speed transmission, 6 speed transmission
Hope this helps
Old Jan 26, 2017 | 03:57 PM
dirty pete's Avatar
Are you still having this problem? I experienced this the other morning and I stuck the trans in 2nd gear and rolled it forward then put in reverse and it went in,go figure.
Any way, I know I am pass due changing the fluid which may be my problem. Good luck with it.
Let us know how or if you fix it.
Old Jan 26, 2017 | 06:50 PM
Danderson's Avatar
My issue is cold in the morning(cold in San Diego is 30* after backing out of the driveway. In order to gewt it out of reverse I simply recycle the clutch. I've tried pulling it out of reverse while backing up with clutch disengaged to no avail.
After warming up the trans no issues the rest of the day.
Busboy
Jan 23, 2015 01:12 AM
Jim Dynomite
Oct 24, 2011 11:28 PM
Steve034x4
May 18, 2010 10:08 PM
TPilaske
Feb 6, 2006 07:20 PM
