G56 trans jumping out of reverse gear
Old May 14, 2010 | 08:01 AM
Steve034x4's Avatar
From: North of the Frost Line....near Priddis Alberta
When backing down a steep hill in reverse gear (ie. engine compression braking) the transmission jumped out of gear into neutral. I've been able to reproduce this several times, but you need a steep hill - 10-15% grade or better. The dealer couldn't reproduce it....OK I've now gone back a second time and told them to find a steeper hill.
I'm told that there is a reverse lock to prevent this, but my lock is unlocking...
Anyone else have this issue? Still under warranty, so good news there.
Old May 14, 2010 | 03:21 PM
SpeedyWS6's Avatar
Reverse lock out will not keep it from popping out... When it pops out is it with abrupt throttle changes?
Old May 17, 2010 | 09:25 PM
Steve034x4's Avatar
hi Speedy,
When it pops out I'm backing down a steep hill on loose gravel, so chances are the wheels are chattering. I've been told that loading and unloading the gearbox will cause this, so I gues it's normal.....Steve
Old May 17, 2010 | 09:32 PM
torquefan's Avatar
If there is a steep hill near the dealer, where you know you can duplicate the problem, they may let you stop by and take the transmission technician for a quick drive so you can show him yourself.
Old May 18, 2010 | 02:24 PM
Grit Dog's Avatar
Thought G56 trans came out in the 06 models??
Old May 18, 2010 | 03:18 PM
tool's Avatar
Late 05 models came with the G56 as well.
Old May 18, 2010 | 10:08 PM
SpeedyWS6's Avatar
Yeah I was gonna say that it was probably a result of the operating conditions.
Busboy
Jan 23, 2015 01:12 AM
Jim Dynomite
Oct 24, 2011 11:28 PM
ckoIII
Jul 14, 2005 12:25 AM
RamIt600
Jun 5, 2005 10:03 PM
