DTT master rebuild kit
Old May 17, 2010 | 07:39 PM
sladek15's Avatar
So I think my front clutches are toast and Im thinkin about rebuildin the transmission. Im thinkin about doin it myself and have built a couple GM trannys before and dont have the money to go out and buy a full billet tranny from someone. Also I like doin projects on my truck myself cause it make me feel better when i see the finished product. But my question is, what all is included in the DTT master rebuild kit for the 04.5 48re transmission. I just bought DTT's tripple disk t/c and valve body and im plannin on buyin the billet input while im in there, but what all is included with the master kit. Will I need anything else or does it have everything ill need to do the rebuild? Besides specialty tools of course but I have access to thoses. Thanks in advance.
Old May 18, 2010 | 06:47 PM
Shagginwagon's Avatar
Call and talk with Stephan or Shanti. You can order the rebuild kit how you want it. Meaning, if there are specialty tools need to put in a certain piece, they can put that piece together before it ships. You really can custom order a rebuild kit and do as much or little of the install as you like.
That said, the rebuild kits come with new clutches, frictions, servos, accumulator piston, plus a bunch of other stuff. If it is a plastic OEM part, then it is most likely upgraded to billet. You might also think about replacing the OEM pressure governor assembly (?) with a GM unit as they are more durable.
I don't know much about transmissions, but I did just order up a tranny from DTT, and we covered a lot of this stuff. And it's just flowing out of my fingertips. It's getting installed in a couple weeks. Master rebuild with triple disc TC, billet input/ output/ flexplate and I'm think I'm gonna get the shift enhancer too. Hope I got some of it right. Give 'em a call.
I'll PM you the phone number.
Old May 18, 2010 | 10:34 PM
sladek15's Avatar
Well i have their phone number cause i already ordered their tripple disk t/c valve body, billet accumalator, billet anchor and strut, and the gm conversion kit, and i was gonna call them i was just wonderin before i called.
justin mcfall
Dec 4, 2009 06:16 PM
Mike Holmen
ABDTR #5
27
Apr 7, 2009 10:13 AM
Ilikebikes
Oct 11, 2006 07:56 PM
S.Dodge
Aug 26, 2006 09:01 PM
