fuel sending unit problem need help
Old Nov 14, 2011 | 06:57 PM
bigbear4x5's Avatar
i had a line break off my sending unit i am not sure if it was the return or pressure i think the return it was leaking fuel and when tried to get the line off the fitting broke off. where is the best place to buy a new sending unit and also how much fuel should be going through the return. with the truck running before the line broke it had a good bit of fuel dripping off the tank and the biggest part of the tank was wet. should there be that much fuel or do i also have something else wrong also it has had the in tank conversion done by the dealer about 2 years ago.
Old Nov 14, 2011 | 07:26 PM
BigIron70's Avatar
Cummins Guru
Most likely the return line since engine wouldn't run very long if it was the supply line. New module around $300 at dealership.
Old Nov 15, 2011 | 01:19 AM
bigbear4x5's Avatar
how much fuel should be coming through the return line at idle?
Southern Pride
May 18, 2010 07:47 AM
JasonblkZ06
May 16, 2009 08:02 PM
Need95-00CTD
Jan 17, 2009 08:36 AM
zkhoss
Apr 19, 2005 01:49 PM
