bigbear4x5 |
11-14-2011 06:57 PM |
fuel sending unit problem need help
i had a line break off my sending unit i am not sure if it was the return or pressure i think the return it was leaking fuel and when tried to get the line off the fitting broke off. where is the best place to buy a new sending unit and also how much fuel should be going through the return. with the truck running before the line broke it had a good bit of fuel dripping off the tank and the biggest part of the tank was wet. should there be that much fuel or do i also have something else wrong also it has had the in tank conversion done by the dealer about 2 years ago.
