fuel line size
Old Mar 8, 2012 | 04:18 PM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
fuel line size
Good day all,
Does anyone know the size of the steel supply lines(from OEM fuel filter to CP3)? I'm installing a Vulcan Diesel air horn mount fuel filter system. It came with 3/8" hose which looks too large(I.D.) for those steel supply lines. They look way too small(O.D.). Thanks.
Andy
Old Mar 8, 2012 | 05:22 PM
DodgeRam24V's Avatar
what are you going to do, hook the 3/8 id to the steel od?
Old Mar 8, 2012 | 06:13 PM
Eat Beef's Avatar
Yes. I have a vaacum pump in my way so I can't use the fittings. I need to tie into the steel supply line.
Old Mar 9, 2012 | 04:00 AM
i can measure one at work and let you know the od tonight,
for some reason this site will not load up at work, every other site comes up fine? all i get is the top portion and the banners.
Old Mar 9, 2012 | 08:26 AM
Eat Beef's Avatar
Okay, thanks. If lines are too small, I may have to go with a smaller fuel hose and change the fittings on the filter head.
Old Mar 9, 2012 | 08:57 AM
Shorts's Avatar
I've got some hose from GDP that I installed my MKII kit with (not big line). I'll double check the size for you as well.
The hose fits over the hard lines and secured with the spring clamp. I haven't had a problem there with leaks.
Old Mar 9, 2012 | 09:34 AM
Scotty's Avatar
Top's Younger Twin
From what I recall, the supply line is 3/8 OD and the return line is 5/16 OD...I could be wrong on that, it could be the ID. I am certain the 3/8 hose you got for your kit will slip over the steel supply line and clamp on...I have done a few of those. Why do you think its different? Did you try putting the hose over the hard line?
Clear as mud hey?
Old Mar 9, 2012 | 05:28 PM
i had a truck in the shop today for forgot to measure it, sorry, will do tomorrow.
you could do something like this:
http://www.jegs.com/i/Earls/361/8076...arentProductId=
Old Mar 10, 2012 | 10:26 PM
Eat Beef's Avatar
Clear as mud hey?
Haven't tried to put it on yet. It just looked like the hose was too large (I.D.)
I don't have calipers to measure so I did measure them with a tape measure. It looked like the supply line was 5/16(O.D.) and the rubber hose (I.D.) was 3/8.
Old Mar 10, 2012 | 10:29 PM
Eat Beef's Avatar
That would be good, thanks.
Old Mar 22, 2012 | 06:10 PM
Shorts's Avatar
5/16" ID
Sorry took me so long
Old Mar 23, 2012 | 12:19 AM
Eat Beef's Avatar
Shorts, thanks for your effort. The hose that came with mine is 3/8" I.D. It's okay, I've got it figured out.
89f150
Dec 11, 2008 10:21 PM
alaskanassassin
Apr 10, 2007 12:08 PM
Ace
Mar 7, 2007 04:49 PM
blueberry
Oct 3, 2005 08:23 PM
bluebull
Jan 22, 2005 09:48 PM
