Fuel going everywhere.
Old Sep 27, 2014 | 01:44 PM
Tarosean's Avatar
Sitting on the side of the road waiting for a tow. 07 5.9l 210k 6spd.
Truck gave a shutter engine light came on then died.. Coasted to a safe place and diesel was pouring from under the truck. Turned the key off and popped the hood, and fuel was all over the back of the engine, & dripping everywhere.
Any common issues?
Old Sep 27, 2014 | 05:14 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
#4 and #6 injector feed lines are known to crack causing that issue...easy to replace and not very expensive.
Old Sep 27, 2014 | 05:23 PM
.boB's Avatar
Most likely #4 injector line.
https://www.dieseltruckresource.com/...e-t313759.html
Old Sep 28, 2014 | 08:37 AM
verdesardog's Avatar
probably a fuel line, I carry a spare #4 tube in my tool box.
Old Sep 28, 2014 | 01:11 PM
Tarosean's Avatar
Thanks for the ideas. Hopefully it is that simple.
Old Sep 28, 2014 | 05:25 PM
ChrisJohnson's Avatar
Same thing happened to me. Thought it was the # 4 line, had a spare, changed it out, and after all the work (not that hard), found out it was a loose # 6 line. # 4 is easy to work on, # 6 is a little harder. Anyway, have a new # 6 line, and a new # 4 upgraded line in my oil burner.
Old Oct 1, 2014 | 11:52 AM
Tarosean's Avatar
It was the #6 line... 156.00 repair bill is probably the cheapest Ive ever paid for that truck....
Old Oct 2, 2014 | 10:06 AM
rockcrawler304's Avatar
You should buy a #4 line to keep in the truck just in case! A couple wrenches is all you need to change it out. I did my in a parking lot a few years ago. Took about 10 minutes tops.
JBradley500
Jul 31, 2010 12:06 AM
Megaramasaur
Sep 29, 2008 10:31 AM
1965427AC
15
Feb 10, 2007 06:03 PM
djgaston
Nov 27, 2006 02:38 PM
