fuel Filter water drain
Old Jun 9, 2005 | 09:27 PM
Jmac's Avatar
Hello All,
How come my drain isn't draining? It's very slow took almost 10 min to drain when I changed the fuel filter today.
I did try to crack it open for a couple of seconds about a week ago, and it flowed nicely. I thought that fixed it. NOPE!!!
thanks Jamie
Old Jun 10, 2005 | 09:50 AM
Lightman's Avatar
Did you have the top of the filter cannister open? That helps.
Old Jun 10, 2005 | 09:59 AM
jkitterman's Avatar
Sometimes it gets plugged. Open the valve and make sure you have something to catch the fluid set up and then just turn the key to 'on' for just a second and then back off. The pump with usually clear the plug.
Old Jun 10, 2005 | 02:57 PM
Jmac's Avatar
Cannister was unscrewed all the way. My origional post should have read that the motor was running when I cracked open the valve... it flowed very nicely. Should I try that again?
Jamie
Old Jun 10, 2005 | 06:42 PM
John Halter's Avatar
From: somewhere in northwestern ohio....Mansfield, Oh
Mine was same way, I turned valve on and ran lift pump and cleaned out the problem works great now.
ZPOD
18
Sep 23, 2010 10:37 AM
Journier
Nov 25, 2005 08:41 PM
marv h.
Sep 20, 2005 02:33 PM
bausman
Jul 29, 2005 07:54 AM
jbeauv
Sep 16, 2004 09:13 AM
