Fuel filter help
Old Jan 5, 2010 | 08:33 PM
Pikeman's Avatar
Fuel filter help
Just wanting to know what the highest efficiency drop in filter to fit in the stock location is. I have been using the standard filter since my truck has been new and changed it regularly with no problems but with so many people having injector problems I think I may start using something better. Whats the part # and where do you get them. Thanks!!!!
Old Jan 5, 2010 | 08:44 PM
Dr.Dizzle's Avatar
Baldwin PF 7977 ... 5 micron absolute at 98% efficiency. Here is the Baldwin link in order to locate a supplier near you.
http://www.baldwinfilter.com/
Old Jan 5, 2010 | 08:45 PM
nelrod's Avatar
Baldwin PF 7977 if my noggin remembers correctly. 5micron drop in, anyway that is what I use and get it from a local Fleetpride truck parts business/
Old Jan 5, 2010 | 09:20 PM
Pikeman's Avatar
Thanks guys
Old Jan 5, 2010 | 10:02 PM
bansh-eman's Avatar
If you have a Grainger near you they carry Baldwin as well.
Old Jan 6, 2010 | 09:21 AM
eot's Avatar
eot
hey all I just took your advise called a local dealer on these filters they were cheap! 14 bucks apiece! I hope they are good ones! I will put one in on friday!
Old Jan 6, 2010 | 10:01 AM
Lost Lake's Avatar
Well I don't want to upset the apple cart here, but I just talked to Baldwin yesterday.
The technical engineer I spoke with said the 7977 used to be rated at 2 microns, but now is 5 microns single pass. I asked about the 2 micron Cat filter and he scoffed and said there isn't one. Since the standard for testing has changed, all 2 micron filters are 4-5 micron filters now.
Then I asked him about the Cummins / Fleetguard FS19856 which is rated at 7 microns and uses the stratopore material.
The Baldwin engineer said the FS19856 was a great filter, and probably would pass the 5 micron test. Then he went into a long lesson about fibers and testing methods and how they have changed and why 2 microns is now 5 and flow rates and number of passes and on and on and on.
In the end I came away with this:
Cummins is warranteeing my engine. If it has a problem with a Cummins FS19856 filter on it, they won't batt an eye at it.
If it has a Baldwin PF7977 on it when an injector goes, I will have to ask Baldwin for the money.
And in the end, when I asked the engineer from Baldwin which was the best filter for my Cummins with Bosch injectors (this was the design engineer, not tech support --- I was passed off to this guy because I specifically asked about multi-pass versus single pass testing) anyway, when I asked which one would give me the BEST filtration, he said it was a toss up, and either one would be excellent.
I'm going with the Cummins filters. I can get them for $16 locally.
Old Jan 6, 2010 | 10:24 AM
BigIron70's Avatar
Cummins Guru
Read the following TSB from Chrysler may save you some $$ down the road.
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
Lunyfringe
Jan 10, 2005 05:40 PM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
