Fuel Filter change, How often?
Old Apr 21, 2008 | 10:11 AM
  #31
AH64ID's Avatar
My dad and I got them at a marine supply warehouse....
Old Apr 22, 2008 | 10:09 PM
  #32
VFDFireman's Avatar
Has any one had any experince with Hastings fuel filters? Local repair shop wants to sell them to me over the counter for 11$. Sounds like a deal to me. Anyone know if they have atleast a 7 micron rating?
Old Apr 22, 2008 | 11:57 PM
  #33
laramie5.9's Avatar
Just picked up a baldwin PF7977 filter from the local peterbuilt shop for $10, not sure if it specs at 5 mics or not?
Old Apr 23, 2008 | 12:42 AM
  #34
laramie5.9's Avatar
Was just on the Baldwin website at they say the pf7977 meets cummins new requirements for the 02 to 06 engine. I found it in a engineer bulletin dated march 6 2006. Not sure what the new specs are.
Old Apr 23, 2008 | 08:53 AM
  #35
AH64ID's Avatar
I was curious so I emailed hasitings... looks like it is the same filter as the Baldwin PF7977... infact the email came back to me from a Baldwin/Hastings rep (the same one I email with at Baldwin)....
The absolute micron rating on the FF1260 is 5 and the capacity is 25.5 grams.
Old Apr 23, 2008 | 09:27 AM
  #36
Roperteacher's Avatar
Yes, the Baldwin is 5 microns. I use that in my stock canister and also run a 2 micron GDP se tup..
Old Apr 23, 2008 | 01:00 PM
  #37
laramie5.9's Avatar
Here is another question, when installing it I assume the hole in the base of the filter goes down, if any one could correct me if I am wrong that would be great!
Old Apr 23, 2008 | 01:01 PM
  #38
ptgarcia's Avatar
Yep, goes down. The non-hole side of the filter snaps into the canister lid. Once you take everything apart you'll see how it goes back together.
Old Apr 23, 2008 | 07:12 PM
  #39
DiEseLjunKy's Avatar
Originally Posted by carl48
the dirtier the fuel filter get's the better it filters add a fuel gauge and change the filter when the pressure under load drops a couple of pounds from normal and use the baldwin 7977 depending on where you get your fuel you can get about 75,000 miles per filter
That may be so with an oil bypass but a dirty fuel filter restricts flow and robs power.
Old Apr 23, 2008 | 10:17 PM
  #40
Hounddog's Avatar
After it gets to a certain saturation level.
ptgarcia
Sep 15, 2006 03:56 PM
drew03
21
Sep 19, 2005 05:46 PM
coobie
13
Mar 16, 2004 06:55 AM
Varmint
Mar 7, 2003 04:58 PM
Jones0027
23
Dec 22, 2002 09:41 PM
